Previous in Forum: What may be the effect if we run turbine in low load?   Next in Forum: CRUDE OIL WATER SEPAATIONS BY GRAVITY
Turbine Design
01/25/2008 8:23 PM
Sir can you pls provide pfd files on condensing turbine design?
Raju
Re: Turbine Design
01/25/2008 8:38 PM
Re: Turbine Design
01/26/2008 10:47 AM
Me do not standunder from steam. U give me more plz.
me want good job me take 4 wife and 17 childs.
wheer 2 buy paper with red star in America. me write my name self.
Re: Turbine Design
01/26/2008 10:58 PM
"Sir can you pls provide pfd files on condensing turbine design?"
Regret to inform you:
A complete design of a steam turbine of any kind is not going to be found on line. Such designs are done to specifications for a given application or installation.
Re: Turbine Design
01/29/2008 3:44 AM
Google for M-cycle and Maisotsenko via this link
www.idalex.com
www.coolerado.com
www.rexresearch.com/maisotsenko/maisotsenko.htm
And this
At the heart of the MCTC is the Maisotsenko Compressed Air Saturator/Turbine Exhaust Cooler. This equipment uses existing shell and tube heat exchanger technologies, built in a new configuration. Idalex is working closely with Yuba Heat Transfer, a Division of Connell LP, who has completed the design and heat transfer calculations for the Maisotsenko Compressed Air Saturator and Turbine Exhaust Cooler. Schematically, the equipment is represented by:
The state points on the above diagram are plotted on the following psychrometric chart:
Benefits of the MCTC include:
  1. Efficiency above 60% in a simple, single cycle.
  2. Renewable, atmospheric energy performing one-third of the work.
  3. Small efficiency loss over a power band from 60% to 100% of full power rating.
  4. Lower NOx emissions by more than 90%.
  5. Cost effective application of the benefits of the Humid Air Turbine Cycle to all combustion turbines including micro-turbines.
This new development in thermodynamics has already been reviewed and challenged by some of the greatest minds in the field. However, it is important that everyone be given the opportunity to learn, analyze and question these claims. It is with much anticipation and exhilaration that I invite my esteemed colleagues from around the world to review and share in the application of the phenomena that I have devoted my life to study and capture.
An abstract of the ASME paper can be found at: http://www.asmeconferences.org/IGTI03/ by typing in GT2003-38080 into the search option. Other information can be found at: www.idalex.com/
Kind Regards, Randolph Toom - www.heat2power.net
Re: Turbine Design
02/07/2008 12:05 PM
He says he is from Tanzaniya.
But he is India Stock all right-and the expectations!!
Re: Turbine Design
02/08/2008 4:49 AM
Oh Dear!!
Register to Reply 6 comments
Andy Germany (1); Anonymous Poster (1); MUKULMAHANT (1); Randolph Toom (1); Steve S. (1); Stirling Stan (1)
