Previous in Forum: Industrial Harmonics   Next in Forum: Hydraulic solenoid / pilot valve testing
FAILURE OF 'K' TYPE THEMOCOUPLE
01/26/2008 2:14 AM
WE ARE USING 'K' TYPE THERMOCOUPLE IN OUR CEMENT LANT FOR TEMP MEASUREMENT UP TO 1000 DEG. CENT.THE SPECIFICATION OF T/C IS AS UNDER.
INNER SEATH :MI CABLE WITH 6 MM DIA IS MADE OF SS310
OUTER PROTECTION SEATH : 22 MM OD/14 MM ID HRS 446 METAL
LENGTH: 1000 MM
APPLICATION:IN CEMENT PLANT CALCINER INLET TEMP. HAVING OPERATING TEMP. IS 870 TO 950 DEGREE CENT.SOME TIMRS IT GOES TO 1000 DEG.CENT.
LIFE WE ARE GETING IS: AROUND 15 TO 20 DAYS.
PLEASE GIVE YOUR SUGGESTIONS FOR IMPROVEMENT.
Good Answers: 143
Re: FAILURE OF 'K' TYPE THEMOCOUPLE
01/26/2008 7:34 PM
Oops, thought my post went through and it didn't.
Go to
www.omega.com
and check out their sheaths. Sounds like you might have chloride accelerated corrosion. You may need Inconel or even Carpenter 20.
Good Answers: 18
01/26/2008 11:29 PM
May want to consider 446 SS as a thermowell.
Location: Mostly Antwerp, Belgium but also all over the world
01/27/2008 6:12 PM
At that temperature I would not recomend a K-type anymore. Go for a N-type with a Nicrosil thermowell. I had good experience in a die decarbonizer/incinerator with oxidizing temperatures over 1000 °C.
01/28/2008 6:05 AM
Please be so kind as to turn off the Caps Lock function.
Another option might be to go for a non-contact measurement system, like an laser thermometer.
02/03/2008 11:44 AM
HI,
My suggestion is please go for INCONEL 600 Material for inner & outer sheath because specified SS material work upto 800 Deg C only.
agua_doc (1); ja.sr (1); pappu (1); PWSlack (1); TVP45 (1)
You might be interested in: Cement Boards, Thermocouple Wire, Cement Tiles
