Previous in Forum: Power Line Communications Systems   Next in Forum: Laplace transform
13 comments
Monitoring serial communication/reverse engineering a protocol
01/27/2008 4:33 PM
Hi,
I have limited knowledge about communications and communication standards, and I am now trying to get a device (PLC) to communicate with/aquire data from an inclinometer. The problem is, I do not know what commands I should send to the inclinometer, and what data I should expect to recieve from it. The communications protocol is RS-232C (I think). I have some software that came with it, which let me see trend curves and such, but doesn't reveal anything useful communication-wise. I have found no documentation of the macros sent back and forth. So, my question is: can anyone tell me how I should go about this?
Thanks
Re: Monitoring serial communication/reverse engineering a protocol
01/27/2008 5:28 PM
Hi,
Unless you have a digital storage oscilloscope or a serial data analyser and know how to use 'em.
OR
You have good manuals for the products at either end of the wire, the patience and wit to slog through them both and understand them.
Then I'm afraid you have a very difficult task with little chance of success..
My best advise in that case is to get some help from someone familiar with the devices... maybe try their tech' support or web sites...or if you buy enough product maybe a tech' rep'?
Good luck
Good luck
01/27/2008 6:33 PM
If I understand correctly, you have an inclinometer, which came with a cable for connection to a PC serial port, and some software to run on the PC. Am I right so far?
If this is the case, you should be able to get the comms protocol information from the supplier (or manufacturer). I can't see any reason why they'd not release that kind of data. Maybe there's a technical manual that they don't usually distribute (because most users don't need it).
BTW -did you get it (new) recently, or have you 'inherited' it (one way or another)?
If it's old kit, you're probably back to Del's take on it. Tricky!
Good Answers: 247
01/27/2008 7:09 PM
I agree with what Del and John have said. You may find that if you google the brand and model number you'll find someone who is using that model who knows its ins and outs.
Sometimes the command to get a device to do something or return data is in plain English. I used to fool with laser disc players, and some would play given some code like B2 or 2&@[[, but others would play given PLAY (imagine that!). So if all else fails, you could use a terminal program and just type anything that seems likely and see if you receive data back. If you were lucky, I suppose you might find it simply sends data in a stream once it receives a "clear to send".
You mention software. Does it communicate with the device? If so, then your job may be easier, because you could set up a laptop to emulate the device, and see what the software sends to the device.
01/28/2008 3:58 AM
Dear Sir,
First of all if you require data monitoring only without any control output then any data logger ( RECORDER) will fulfill you purpose in that case the out put from your inclinometer ( 4-20 mA or Volt) should be connected to data logger which will monitor the data & simultaneously the DATA LOGGER should have RS232 or ethernet comm. port from where it can be connected to PC for real time data monitoring .
IN case you have PLC with SCADA for data monitoring & controlling then O/P from inclinometer should be connected to PLC i/p module .PLC should again have the communication port to connect it with PC where you can monitor the data with SCADA software.
REgards
Rakesh Bhat
01/28/2008 4:45 AM
Hi,
Thanks for all the answers! Well, I haven't mailed the manufacturer yet, but I'm about to do that now. It is a 'FAS-G' combined gyroscope and inclinometer from microstrain (www.microstrain.com), and I bought it new. I was just wondering if there was an alternarnative way to obtain the information needed, in case MicroStrain are not willing to give out any information.
01/28/2008 4:51 AM
What sort of barking mad company would sell you something and then not tell you how to use it?...(oh excepting Microsoft of course)
Good Answers: 213
01/28/2008 9:13 AM
If all else fails, there are "sniffer" programs out there (I don't remember the last one I used, but I do remember it was open-source) that can be used to monitor a communications link to determine what is going on (generally requiring a second computer and a hack of a connector to give taps to the #2 & #3 pins). You can see what is sent and what is received. Then you have to translate this in to something you can understand...You probably also need to monitor the other control pins as well. I have encountered MANY companies that consider such information proprietary, Del.
01/28/2008 9:19 AM
All I can say is that if I bought some equipment which didn't say what it's comms protocol was...I'd send it straight back as 'unfit for purpose'....
01/28/2008 10:09 AM
Hi again,
I contacted MicroStrain and they sent me the documentation. Thanks for all your help, though :)
- Eirik
01/28/2008 11:07 PM
A program to communicate through RS232, on your computer is Hyper-Terminal. It is amazing (see what Del mentioned) that Microsoft allows you to use it, without paying royalties!
You may try the Hayes code for modems (AT, +++. etc) it could work for commands. Google for Hayes AT command set.
Bridge rule #1: Nobody is as good as he thinks about himself nor as dumb, as his partner thinks...
01/29/2008 2:35 AM
I like your signature...
Another rule....
Of the 3 other people sitting round the table you may as well believe your partner.
01/29/2008 9:26 AM
Is it enough for advancing to the GURU stature (standing)?
...Your rule is adopted, too (as you know, we hear, learn different things, we digest them in our cognitor and...regurgitate them as our own ideas...c'est la vie...)
01/29/2008 1:30 PM
My Dad had a million bridge sayings... When the ops are dawdling...'play one , look at the pictures on the rest..' always made me smile...
and 'ya cannae play wha' ye havnae got' (his Dad was Scottish)
'Never send a boy on a man's errand' to be said when over trumping your opponent
Anonymous Poster (3); Blink (1); cwarner7_11 (1); indel (2); JohnDG (1); user-deleted-1105 (5)
