Previous in Forum: Piping question   Next in Forum: In Tube Wind Turbine
Steam Condenser
01/28/2008 2:42 AM
I was warking with small steam condenser design from saturation line to 45 degree celusus. but what the probelm is to calculate the convection heat tranfer coefficient. plaes suggest the method?
Location: Earth. England/America -the birthplace of the C. S. A. - anywhere I imagine -home.
Re: Steam Condenser
01/31/2008 8:24 PM
I am interested in steam power and I hope someone can give you an answer. I am actually more concerned with the physical design and size needed to condense a given flow of steam at a given temperature.
No technology is so obsolete that it won't work. A stone knife still can kill you as dead as a laser.
Re: Steam Condenser
02/08/2008 4:12 PM
to calculte it you must know (Q) which generation from it but if you donot know it you know amount of coolant in my countary we use water for example si equal 5 kg/sec and cp=4.18 and ΔΤ=45°(which you say) and then maltiuply it and equal (u*a*ΔtM) only if you donot have it give me data and iwill calculate it but give all this data
Re: Steam Condenser
02/09/2008 8:47 PM
noha - Please repeat that in simple English terms so a math impaired person can understand it. I can't even type some of that stuff in my computer much less understand what Q, cp, delta, u, a, t, and M stand for.
Re: Steam Condenser
03/30/2008 7:50 PM
Go to the following link for further helps you calculate the "U" value (better know as the heat transfer coefficient)
http://www.spiraxsarco.com/resources/steam-engineering-tutorials/steam-engineering-principles-and-heat-transfer/heat-transfer.asp
Good luck!
Dweezle (1); noha (1); Taganan (2)
