Previous in Forum: Steam Condenser   Next in Forum: API Standards for Mechanical Seal Flushing Plans??
8 comments
In Tube Wind Turbine
01/28/2008 2:50 AM
I have a tube, 250mm inside diameter, with air velocity of 200m/h.
I would like to place a turbine to turn an alternator 1-2kW.
Need to transfer wind velocity in to 1000-1500 rpm
Can you help???
Re: in tube wind turbine
01/28/2008 3:02 AM
See other identical thread....
Good Answers: 183
01/28/2008 4:36 AM
Make 1st an attempt to know how much power does the air flow contain. Normally you can recover less 30% of it in mechanical power and further with a loss of round 20% the last in electrical power. The conversion is very simple you compute at which speed the turbine will work (depends on the turbine design) and then you compute which speed amplifier you have to use to obtain the speed you want to have.
01/28/2008 4:53 AM
Does that make any sense?...to anyone?
Good Answers: 183
01/28/2008 5:10 AM
If you do not understand, which can be possible depending of you knowledge of the topics, please formulate your question in a clear way and i shall be delighted to give you ALL the explanations you need to understand.
What do you not understand?
How to compute the turbine sped?
What is a speed amplifier?
Anything else?
Feel free to ask every thing it is not a shame to ask questions!
What i am more surprised is that you did not ask anything about the way an power content could be computed it is in fact the most important step since if the power is too low then it is no reason to go further.
By the way English is not may mother or father language so that i can be less easy to understand using no idiomatic expressions.
Good Answers: 247
Re: In Tube Wind Turbine
01/29/2008 12:36 AM
Do you really mean 200 meters per hour? That would be .055 meters per second, which is far too slow across a 250 mm tube to obtain anything close to 1-2kW.
More on wind turbines here. You can calculate the energy available for a 250mm disc of breeze at .055 m/s, and you will find that even if you converted 100% of the available energy, you wouldn't produce anything close to a kW (or even a watt).
Here is a spec sheet (http://www.windenergy.com/documents/spec_sheets/3-CMLT-1095_Air_Breeze_spec.pdf - sorry, link no longer available) for an available small wind turbine which produces 200 W. Its rotor is 1.17 meters across, and it requires a wind speed of 12.5 m/s for full output. Power varies with the cube of speed, so this turbine would produce (.055/12.5)3 x 200 W, or 0.0000170368 W. It is larger than your tube, however.
01/29/2008 2:10 AM
It is 200m/s
sory
Good Answers: 183
01/29/2008 9:22 AM
Oh here you are gain I am glad. have in mean time understood the deep meaning or have you other questions?
have you computed the energy/power contend of your air stream? With 200m/s you are at about Mach 0.6!
Quite a speed and a tremendous energy behind. How do you generate this flow? Is your intention to recover energy from this flow because 1 kw could be too small. ? Under such conditions the problem will be less the speed amplifier as probably a speed reducer!
You see I am not ashamed to ask questions if I do not understand something.
Good Answers: 247
01/29/2008 10:19 AM
Ah ha! Then you'd have loads of power available.
Pitch is the distance a propeller would advance through the air if it were simply acting like a wood screw. With a 200m/s wind, the pitch required for 1500 rpm would be 200m/s x 60/1500 = 8 meters. This is an extremely high number for a small propeller. (The leading edge of the blades would appear to be pointing almost straight forward.) If you kept the speed down to 1500 rpm, nothing exotic would be required in terms of bearings or structural materials (if the load is only 1-2 kW). However the drag on the blades, even if very carefully made, would be very high, and the blades could break off at the hub from drag alone, or from excessive torque, if the generator locked up. The lower unit of a very small outboard motor (2-3 hp) could be adapted to mount the blade in the tube. (An ordinary water prop -- pitch around .25m.-- could not be used, however, because the rpm generated would be many times too high, leading to destruction of the prop, bearings, personnel standing near, etc.)
At 200m/s the power available is 36003 times as great as at 200m/h. Of course, 36003 is a very large number: 46656000000. This, times the tiny power available at 200m/h (.000017 W) gives you a big number: 793,152 W (793 kW). A good deal of care would be required in design, working around the pipe, etc. This sounds like the output of a jet engine from a biz jet.
In another CR4 post, I put in a link to a windmill blade design paper.
Anonymous Poster (2); Blink (2); nick name (3); user-deleted-1105 (1)
