I've been trying to figure out how add a battery backup to the radio in my boat. It's silly, but I'd like to keep the pre-sets, clock, etc., when the main batteries are turned off between uses. I can create a charging circuit for the backup battery and it will supply power to the radio when the mains are off. However, I need to keep it from supplying power to anything else in the boat. The only thing I can come up with is some sort of switch that will isolate the radio supply when the mains are turned off. However, I think I'm missing a simpler (less brute-force) way of doing this. Anyone out there care to point me in the right direction? Thank you!
