Previous in Forum: Interview Questions for Instrumentation and Control Engineers   Next in Forum: Anyone Interested in Edgerton's Boomer?
Switch Requirements
01/31/2008 6:19 AM
OK-I need some help from my fellow CR4 ers. I need a optical? switch that will turn on and off an 120v a.c. motor when I break the beam with my hand. It will be used inside the house. I want it to be a momentary operation. The range of the beam need only be 10 ft. Any suggestions? Thanks-James
"WORKS FOR ME"
Re: switch requirements
01/31/2008 6:26 AM
Good Answers: 61
Re: Switch Requirements
01/31/2008 11:12 AM
The safety sensor beam from most garage door openers provides a momentary contact closure. Here's one from Genie. Add a latching relay and your all set.
Good Answers: 19
01/31/2008 11:28 AM
Install Photoelectric sensor.On cutting the light the sensor will actuate a relay.the relay will in turn actuate a contactor to switch on a motor.The circuit has to be made and devices to be assembled to achieve the result.
Ramesh,Freelance Electrical/automation Consultant
Register to Reply 3 comments
Anonymous Poster (1); pwr2thepeople (1); ramvinod (1)
