Previous in Forum: Kern Scales   Next in Forum: Conditioning Room Environment
PLC cpu
01/31/2008 10:53 AM
Hi...
Can any one explain to me the working of a siemens PLC cpu. well if u can provide me some good sites then it will be a lot helpful. Thank u.
Re: PLC cpu
01/31/2008 11:09 AM
It's like any PLC:
  1. Read inputs
  2. Do power-up initialization etc (first time only)
  3. Process (ladder/function block) logic
  4. Set outputs
  5. Check communications (if any) for I/O operations
  6. Go to (1)
See the Siemens site for specific details of ladder instructions, interrupts etc.
Re: PLC cpu
01/31/2008 4:49 PM
That sequence is changing. The new Allen-Bradley ControlLogix line has scheduled I/O updates, just not scheduled with the program scan. The state/value of an input could change anytime in the program scan. Good reason to stick with the ages old, "best practice" of buffering your I/O.
Re: PLC cpu
01/31/2008 6:24 PM
Agree 100% - I invariably read into a chunk of memory at start of scan - then often XOR it with a mask (because half the time I don't know which way up the inputs are going to be when I design the logic). Saves hours of changing XICs into XIOs etc.
I do the same kind of thing on the way out.
I put the input & output images (and the XOR masks) in the CIF (Common Interface File (I think?)). I've written a set of routines (VB) using DF1 to read/write the CIF (N7 in M'logix 1000, N9 in most others, as I recall). Means you don't have to stump up the ridiculous sums they ask for RSLINX.
Good Answers: 247
Re: PLC cpu
01/31/2008 11:11 AM
This Wikipedia article will give you the basics.
Follow as many of the links at the end of the article as time allows. Beyond that, you will need the manufacturer's literature for the specific model. You might also look up "ladder logic" on Wikipedia. It is implemented in many PLCs, and even if it is not implemented on your make and model, it gives you some insight into how PLCs think.
Blink (1); JohnDG (2); Kilowatt0 (1)
You might be interested in: CPU Cards and Modules, CPU Chips, CPU Fans and Coolers
