Previous in Forum: Hatch is Too Small   Next in Forum: third law of thermodynamics...
design of Basket filter
02/02/2008 1:19 AM
We are having basket strainer model : BASP-ST-12-150 in reference to code ASME SEC VIII DIV -I with design flow rate of 9000000LPH. Whether the Flow rate can be increased to 1200 kl/hr.
Please confirm
A.J Chakraborty
Maintenance Manager
IOCL, Haldia
Good Answers: 266
Re: design of Basket filter
02/02/2008 7:24 AM
With a designed flow rate of 9000000 liter per hour which is 9000 kilo liters per hour. I do think it would easily hand 1200 kilo liter per hour.
02/02/2008 11:10 PM
I think there is something wrong in your question.
You have stated the design flow as 9000000 LPH i.e. 9000 kiloliter per hour (kl/hr) and enquired whether the flow can be increased to 1200 kl/hr. If the design flow is 9000 kl/hr then with a reduced flow of 1200 kl/hr, there should not be any problem.
02/04/2008 2:50 AM
Increasing or decreasing the flow rate is not a problem, anyway you have to take into consideration the recommended velocity of that fluid to avoid maximizing of pressure drop through that filter.
Note. I think you mean 12 000 m3/hr not 1 200 m3/hr.
Abdel Halim Galala (1); jitasan (1); ozzb (1)
You might be interested in: Gas Flow Meters, Flow Meters, Turbine Flow Meters
