Previous in Forum: Quartz Plate Deflection Under Vacuum   Next in Forum: design of Basket filter
Hatch is Too Small
02/01/2008 2:38 PM
We have an access hatch that is 12" too narrow for the opening in the concrete slab for a resivoir in a water treatment plant. Any ideas on how to make the hatch work? The ruff opening is 9 ft by 10 ft and the hatch is 8ft by 10ft. The hatch is equiped with a 12" high curb with 3-1/2" flanges around the perimeter.
Thank you everyone for all your feedback.
Good Answers: 97
Re: Hatch is too small
02/01/2008 3:21 PM
What about a 12" extension or beam on 2 of the sides?
What 1/2 is your avatar?
02/01/2008 11:12 PM
"What about a 12" extension or beam on 2 of the sides?"
What about a hatch stretcher?
02/02/2008 12:12 AM
"What 1/2 is your avatar?"
The bottom half
Re: Hatch is Too Small
02/01/2008 11:26 PM
Ask me a toughie! Weld yourself an ell shaped flange onto the puppy so that you get coverage and a safety lip. Now if the hatch had been too big, you might have had a problem.
Ah. I revel in my Godlike powers
If all else fails, read the directions. That's if, and only if.
Hobbies - DIY Welding - New Member Hobbies - Car Customizing - New Member
02/02/2008 12:24 AM
First of all make sure your slab hasn't got them damn stress cables! If you mess with them, they'll mess with you(literally). Second if it has a steel flange already imbedded, just add 6" plate steel to each side. Third if it's just some rebar and concrete, just break away some concrete and form up for a new pour for the proper dimensions. Make sure to drill for and epoxy steel dowels each way. Don't remember the exact requirements; but, I think its like 6" for #5 rebar. Or break away at least enough concrete to get a lap on your steel at least 3 to 5 times the diameter of your rebar(Check code in your area).
02/19/2008 3:59 PM
Thanks for the help.
The architect has agreed to use 2 bent angle as inserts. They are reinforced and will be supported with Hilti anchors. I wish I could insert a drawing so all of you can have a look at it but they also want some flashing to go around it where it is short which I think is a waist of time and money.
Thanks again.
Register to Reply 6 comments
Anonymous Poster (1); Hendrik (1); ktel60 (1); StandardsGuy (1); Stirling Stan (1); Swellmel (1)
