Previous in Forum: is this voltage drop calculation correct?   Next in Forum: RLC Discharge Time
Replacement High Performance Cooling Fan for Canada
02/04/2008 4:48 AM
I am looking for replacement fans to be used in a radio transmitter. The end user will be Canadian so the fan must have UL/CSA approval.
Current axial fans have a physical size that approxiates to a cube with 230mm long sides. Four are packed tightly together in a 2x2 matrix. The airflow is then ducted onto the heatsinks. My searches to date have failed to locate a suitable replacement.
Fan Spec
600CFM with 2" Wg static pressure. 410V ac 3-phase supply although I can redesign the transmitter to accept 208V 3-phase or single phase fans of any voltage. Any suggestions for equivalent fans or a single fan to replace all four (i.e. >2400 CFM) would be appreciated.
Re: Replacement High Performance Cooling Fan for Canada
02/04/2008 9:25 AM
Canada does not use 410V, so that may be one reason you can't find a replacement. The voltages are 120, 208, 240, 277, 347, 480 and 600; although IMHO your best bet would be the lower voltages.
Good Answers: 40
02/04/2008 2:32 PM
This company should be able to help. http://www.ltg-ag.de/56.0.html?&L=3
02/04/2008 11:24 PM
I had a problem as yours, I used a small bank of computer fans from the local computer shop and they worked better x 15% degrees than the originals and cheap to replace.
02/05/2008 5:13 AM
Have a look at ebmpapst.com and find model no. W2E200HK8601 for reference.
Regards Uwe
The sum of intelligence on earth is a constant. And the population grows and grows and .....
02/06/2008 5:34 PM
Try McMaster-Carr in Chicago. They have just about any thing you need, and cover quite a few types of fans. They are on the internet.
Anonymous Poster (1); Graebeard (1); OSPREY (1); techno (1); uweka (1)
