Previous in Forum: Replacement High Performance Cooling Fan for Canada   Next in Forum: Induction Motor Starters
RLC Discharge Time
02/04/2008 5:43 AM
how can i calculate the discharge time of an RLC circuit?
Re: RLC discharge time
02/04/2008 8:01 AM
I think we are going to need a bit more information than that.
What is the circuit layout etc...
John.
02/04/2008 10:00 AM
it is a typical Capacitor discharge through a L and a R in series.
02/04/2008 10:23 AM
Hmmmmm trickey...
You basically have 2 time constants at work here, assuming the capacitor is charged and the inductor is open circuit with no emf present when the 'switch' is closed to form a discharge path from the capacitor through the R and L....
The L & C will form a time constant at a particular frequency with a period of:
τ = 2∏ f √(L x C)
The second time constant is formed from the C and R and is exponential.
The resulting waveform will be an exponentially decaying sine wave with a period of roughly τ...
Hope this helps, I've skipped a lot of calculations as sometimes a guesstimate is adequate.
John.
Register to Reply 3 comments
