Previous in Forum: Harmonic Problem Single Phase   Next in Forum: ALL ABOUT SARAH BOONE
62 comments
Number Theory - Calculations of PI
02/05/2008 12:20 AM
Of course PI (Π) can be determined by measuring a circle's circumference and diameter and dividing. The accuracy will be limited to a few digits. To get a lot of digits, other methods are used (why?). Some methods are much better than others. Vieta produced the first formula:
2/Π = √0.5 * √(0.5 + 0.5√0.5) * √(0.5 + 0.5V(0.5 + 0.5√0.5)) * ... (1)
This is another one:
Π2/6 = 1/12 + 1/22 + 1/33 … (2)
Wallis produced this one:
Π/4 = 2/3 * 4/3 * 4/5 * 6/5 * 6/7 * 8/7 * ... (3)
This one from Leibniz is a special case of a formula from James Gregory:
Π/4 = 1 - 1/3 + 1/5 - 1/7 + 1/9 ... (4)
With formulas like these, the more terms you use, the more accurate the results. Some of them give an answer that is too large, then too small, then too large, etc. with each added term. To implement these formulas effectively, you need to write a computer program. Computer programs follow a series of steps called an algorithm. The algorithms for these formulas need to loop back, adding one or more terms to the calculation each loop. This kind of process is called an iterative routine. Most computer languages have a fixed amount of accuracy or precision. Some give you a choice of two. Seven digits of accuracy is called single precision. You get 16 digits with double precision. For more digits than this you need special systems or special programming.
I implemented formula 3 with 2 terms averaged per loop. When done with single precision it converged on the number 3.141330, which is incorrect in the last 3 digits. This demonstrates the result of round-off error. With double precision it got the number 3.141514 after 10,000 loops. That number is correct to 5 digits. Formula 4 was implemented with 4 terms per loop. It got the number 3.141647 after 5,000 loops in single precision, and 3.141621 after 10,000 loops. In double precision it got 3.141618 after 10,000 loops. Formula 3 takes about 20 million terms to get single precision accuracy! Formulas 2 and 4 take about 4 million for the same. Each successive digit with these formulas takes 10 times longer to calculate than the previous one. With formula 4 it took 5 hours for the 10th digit on a Pentium 90 running Microsoft Quick-Basic.
This is a much faster formula that comes from the Hexadecimal expansion of PI:
Π = Σ(n=0 to ∞) {4/(8n +1) – 2/(8n+4) – 1/(8n+5) – 1/(8n+6)} * (1/16)n (5)
Formula 5 (above) achieves double precision accuracy almost instantly in 10 iterations! An even faster algorithm by Robert L. Brown based on arithmetic-geometric mean and circumscribed polygons of constant perimeter (originally discovered by Gauss) is shown below in BASIC language:
1 A = 1: X = 1: B = 1/SQR(2): C = 1/4
2 Y = A
3 A = (A + B) / 2
4 B = SQR(B * Y)
5 C = C - X * (A - Y) ^ 2
6 X = 2 * X
7 PI = ((A + B) ^ 2) / 4C
8 PRINT PI
9 GOTO 2
10 END
This method achieves single precision accuracy in 2 loops, and double precision accuracy in 3 loops! It is the 2nd fastest known method. In a system without accuracy limitations, it can compute PI to thousands of digits of accuracy.
Pathfinder Tags: pi
User-tagged by 2 users
Re: Number Theory - Calculations of PI
02/05/2008 2:53 AM
But wi ?
Good Answers: 74
02/06/2008 11:43 AM
wi not?
Bruce
02/05/2008 5:27 AM
"It is the 2nd fastest known method"
OK - don't hold back on us. What's the fastest?
02/05/2008 7:48 PM
Hi John,
I have been told that the Indian mathematician Ramanujan developed the fastest, but I don't have it. I was hoping some CR4 reader would share it. How about you, guest? You seem to be everywhere!
How did you post that big PI symbol? The CR4 editor won't take it from Microsoft Word, and the internal one looks crappy.
S
02/06/2008 2:42 AM
I cheated with the pi symbol. I also hate the CR4 version, so I ended up doing a Google image search, and grabbed the best-looking one.
Feel free to use it - it's not mine anyway! Right click - save picture as ...
Trouble is you have to insert it as an image, which is a pain.
John
Good Answers: 74
02/08/2008 8:27 PM
The message to the right was written in Microsoft Word, then converted to a PDF, then a TIFF and finallly a JPEG file and brought into CR4 as one image.
I used the Universal Math text for the first three lines and an arbitrary text for the last line. (I think it was called minstral).
A bit of a pain, but you can get the pi you like.
Another way to do it would be to write your message in any word processor you like, then scan a hardcopy into the JPEG format and bring it in as an image.
Maybe someone else has a more practical suggestion.
Bruce
02/08/2008 10:36 PM
Hi ba/ael,
How did you convert the PDF to a TIFF? Was there another program involved? Please give me the whole details. Sparkstation has a thread about inserting graphics into CR4 posts. I have been trying to use IrFranView which he suggested. It's a pain too. I think that CR4 needs to find an editor that is more compatible with Microsoft Word.
You said you used the Universal Math text. Is that an add-on? I don't seem to have it in my Word.
S
Good Answers: 74
02/09/2008 12:09 AM
Hi StandardsGuy,
Yes, there was. I used Bluebeam Revu which is combined with my Microsoft Word to create the TIFF, then Irfanview reads the TIFF and makes the JPEG. The following is the result.
Bruce
Good Answers: 74
02/09/2008 12:19 AM
This was a scan that I made from a paper copy, then brought it in as an image to the CR4 Editor. I'm not sure that it was worth all the trouble, but it does work and we can have whatever Greek letters we are able to generate on our word processor.
Bruce
02/09/2008 11:48 AM
This looks good. I may try it next time. I've posted my last Number Theory thread using IrFanView. I copied the formulas 1 by 1 to the clipboard, pasted them into IrFanView, then saved them as JPEG files. I then uploaded the Word file to CR4, then inserted the formulas with the camera symbol, and cleaned it up. The formulas take up most of a line this way, but that's OK. I used text size 16 and a bolder font for the formulas to make them show up better. I think your scanning idea would be simpler and quicker.
02/09/2008 4:40 PM
This line includes the pi symbol p - p - from the Word 'Insert symbol' function. 1st version is 10pt (same as the text), it's a bit small, so second version is upped to 14pt.
The line (or two) above was written using Word, & copy'n'pasted into the CR4 New Comment box. No jpegs, tiffs or anything else - just the clipboard. I've surprised myself!
I was about to submit this - went to 'Preview Comment' - and found 'p' instead of the pi symbol (which is what, I suspect, you folks will see). This is what it looked like in the New Comment box before preview:
(This is a bit of screen-grab done using 'Jasc Paint Shop Pro')
02/09/2008 4:44 AM
פ') לאגור, לצבור לעת הצורך (כסף, מזון וכו')
I just copied this from a Hebrew translator, and it even backspaces left to right !
Hope it comes out the other side of the editor OK.
02/09/2008 4:48 AM
Yep, and I can copy from the above post to word, edit, and re-paste to CR4 as text;
אגורהצורך (כסף, מזון וכו'
Good Answers: 74
02/09/2008 11:49 AM
Great Kris, but how does your π (pi) look?
Bruce
02/13/2008 3:37 AM
Ah, I see the dilema. Seems odd that it accepts all those funny lettering I used earlier. I need to re-read all the post you guys have made.......
02/09/2008 12:16 PM
Kris,
Things always look good when you paste them into the text box on CR4. It's when you review the text that everything goes bonkers.
S
Popular Science - Cosmology - New Member United States - Member - New Member
02/09/2008 8:25 PM
Hi Kris,
Now here is a large п and a small π. In addition we can insert any of numerous math symbols such as ω ψ χ φ and so on. This is not MS Word, but Open Office 2.3, which, in my opinion is much better than Word. It's also open source and free!
No conversions or any of that nonsense. Just copied it directly from OO2.3 directly into new comment editor.
Interesting that the small PI above looked just like the one in JohnDG's post (#8), before I previewed it. After that it looks as you see it above.
-John
All worthwhile programmers know that constants always vary.
Good Answers: 61
02/06/2008 1:17 PM
Ramanujan developed the convergent series shown below. More details are available at http://planetmath.org/encyclopedia/RamanujansFormulaForPi.html (Sorry, link no longer available.)
02/06/2008 3:11 PM
Very cool . Have a point, it's a very good piece of input !
02/06/2008 6:44 PM
Thanks pwr2thepeople,
The formula looks familiar, so I think I have seen it before. Now I know where to find it. Did you see any programs that implemented it?
S
02/06/2008 8:07 PM
0! = 1 by (some strange) definition. Always puzzled me, to.
Can't see any irrational numbers in the denominator.
If you're thinking about √2 (in the numerator), you can find that to arbitrary precision by repeated application of the Newton-Raphson method (if my memory serves me well):
Take a guess. Divide into 2. Take average of the guess and the result. Call this new guess. Repeat.
Guess = 1
2/(1) = 2 (1+2)/2 = 1.5
2/(1.5) = 1.33.. (1.5+1.33)/2 = 1.415
2/(1.415) = 1.413 (1.415+1.413)/2 = 1.414 etc. Getting close!
[Edit: apologies - just re-read and saw (1/√2) in the approximation version. Newton-Raphson still applies.]
Good Answers: 74
02/06/2008 9:47 PM
Thanks JohnDG. I was not familiar with the Newton-Raphson method, but I will take a little time to think about it.
Bruce
02/07/2008 6:37 AM
By coincidence, I was trying to explain it to my 11-year-old daughter the other day.
She had a set of homework questions like:
"Find two consecutive numbers such that, when they are multiplied together, they give the following results:
1) 812."
My idea was to get her to approximate the square root, then pick the nearest two consecutive numbers which, when multiplied, would give a result ending in 2.
800 = 40 x 20, so try 30 (somewhere in between).
812/30 ≈ 27, so √812 ≈ (30+27)/2 = 28.5
8 x 9 ends in 2, so try 28 x 29. Bingo!
02/07/2008 10:19 PM
Cool John,
My approach might have been:
divided 812 by 10 - gives 10 * 81. Too far apart.
Multiply and divide by 2 - gives 20 * 40. Still too far.
Add and subtract the same - gives 30 * 30. Not consecutive.
Try 29 * 30. Product is too big.
Try 28 * 29. Got it!
S
02/08/2008 3:26 AM
We used a similar approach for the first few, then I wanted to bring in the square root idea (she'd already gone way past the required no. of problems on her sheet). Also the fact that the products ended in 0, 2 or 6, so it saved having to try some of the combinations. (e.g. 29 * 30 ends in 0, so must be wrong).
02/07/2008 2:31 AM
Re 0! = 1
(n!)(n+1) = (n+1)!
inserting 0
(0!)(1) = (1)!
0! = 1
02/07/2008 6:23 AM
Oh, yea. All comes flooding back. Ta.
02/07/2008 12:22 PM
Thanks to you too John - I knew the square root iteration, but not it's name. It's very cool, because it zooms in real fast (even with a wild first guess).
02/07/2008 9:53 PM
Hi ba/ael,
Thanks for this. I noticed that it achieves more than single precision accuracy in 1 iteration. I wonder though if it is really faster (for elapsed time) for lots of digits than the 'second best' because of the complexity of the factorials. They would slow down the processing time. Any idea how Ramanujan came up with his formula?
S
Good Answers: 74
02/07/2008 11:57 PM
Hi StandardsGuy,
I can't see how evaluating this expression would be easy or fast. It certainly wouldn't be for me! How he came up with his formula is not clear to me, but you can read more about it at: http://en.wikipedia.org/wiki/Pi.
The following is an excerpt:
In the beginning of the 20th century, the Indian mathematician Srinivasa Ramanujan found many new formulas for π, some remarkable for their elegance and mathematical depth.[23] One of his most famous formulas is the series
which can be derived using the theory of modular functions.[23] The series converges extraordinarily quickly, adding about eight decimals per term.[23] Due to scarce distribution of Ramanujan's published work, it was however not widely known until around 1985 when William Gosper used it to calculate 17 million decimals of π. Based on Ramanujan's ideas, Gregory and David Chudnovsky also found the formula
which delivers 14 digits per term.[23] The Chudnovsky brothers used this formula to set several π computing records in the end of the 1980s, including the first calculation of over one billion (1,011,196,691) decimals in 1989. It remains the formula of choice for π calculating software that runs on personal computers, as opposed to the supercomputers used to set modern records.
Bruce
Good Answers: 74
02/08/2008 12:22 AM
Speaking of pi, which most of us pronounce "pie" but should in fact be pronounced "pee", the expression eiπ = -1 is considered one of the most remarkable equations in mathematics, relating in one simple equation the base of natural logarithms, the imaginary part of a complex number and π (pi)
, Euler's identity, named after Leonhard Euler, is the equation
where
is Euler's number, the base of the natural logarithm, is the imaginary unit, one of the two complex numbers whose square is negative one (the other is ), and is pi, the ratio of the circumference of a circle to its diameter.
Euler's identity is also sometimes called Euler's equation.
Bruce
02/08/2008 4:40 PM
Wow, an even better one! You get a gold star. This one has 3 factorials instead of 2, but yields 14 digits per term instead of 8! Interesting stuff in both of your new posts.
S
02/05/2008 6:17 AM
The current record for Pi is over a Trillion places. Forgive me for not posting them !
I like QBasic (), though I haven't tinkered with it for ages. I once set up a sub-routine to increase the precision ( Microsoft Excel couldn't deliver what I wanted) for some daft bit of curiosity research. QBasic seems to have a bit of a cult following.
What's with the Pentium 90 - Have you run Prog 4 on a fast processor, or you just having a bit of retro fun ?
02/05/2008 11:02 PM
I think I had bought Quick-Basic before Qbasic came out, and Qbasic is less powerful, so I never used it much. Now I mostly use HP Basic for windows (now written by Transera). It has PI built in and uses double precision, so you don't need to define PI in your variables list.
"What's with the Pentium 90 - Have you run Prog 4 on a fast processor, or you just having a bit of retro fun ?
Although I have never had the latest and greatest, this was done a few years ago, and I have not run it recently. BTW, the number theory series was to be a chapter in a math book that has never been published.
S
02/06/2008 3:19 AM
Thanks S,
I shall have to go back and look at my version of Q-Basic. I think it shipped free with WFWG, and has Pi built in ( very possibly wrong - I sort of recall entering a value now I think about it. Finding work-rounds for it's shortcomings is half the fun. I've subsequently copied it across to newer computers, because it's so easy to use. It also does the job for stuff that I tinker with. I wouldn't want to do graphics with it (though I've seen some nice ones). VB just doesn't seem like programming to me, but I never invested any real time in playing with it.
Was the book you mention one that you've been working on ? It sounds interesting.
Kris
02/06/2008 6:48 PM
"Was the book you mention one that you've been working on ? It sounds interesting."
No, I haven't for a while. I use it for notes when I forget how to do something.
02/06/2008 7:38 PM
Coincidentally, I was over at the factory (I'm a solo (mostly) electronics/software guy, but they pay me - as in my biggest contractor) looking at a new build, when I was asked to look at an old bit of QB45 stuff I'd written years ago for up/downloading CNC progs to a Bridgeport mill.
They'd scrapped the Win95 machine & tried to run it on a "new" XP box (about 5 yrs old!). Clapped out with Error 76.
The old system accepted "C:\dirname\" as a valid path, but the new one would only take "C:\dirname".
"CD C:\dirname\" worked from the command line, but "CHDIR C:\dirname\" in the code gave the error 76. ??? Beats me.
Anyway, it works now.
02/05/2008 8:25 AM
Pi = 3.14159265359. This should be close enough using CAS on an HP graphing calculator in approximate mode. Far better than double precision and no coding required. The CAS system on this calculator is very powerful and will exceed anything you are likely to code.
In exact mode, pi will be placed on the stack for use in subsequent calculations.
02/05/2008 8:55 AM
Wow! I never knew finding was that easy! I must go out and buy one of them.
02/07/2008 6:11 AM
I've got Russel Webb's RPN calculator on my ancient palm. It displays (and uses) ∏ to 16 digits.
Absolutely brilliant calculator! $29 (As long as you've a palm OS devise)
http://www.nthlab.com/
02/06/2008 3:03 PM
There is also the Monte Carlo method of approximating Pi using the unit circle inscribed within a unit square. Using random number generator to generate x and y coordinates between 0 and 1, count the number of instances where x^2 + y^2 <= 1, multiply that number by four, then divide by the total number iterations to get the approximation of Pi. Of course, this is not a speedy method, and the fidelity of the result will depend on using a large number of samples, and the randomness of the random number generator.
I guess we could use Pi as the basis of the random number generator -- D'oh !!
02/06/2008 3:07 PM
This is just a cunning ruse to play blind-folded darts down the Pub. Excellent strategy Sir Robin !
02/06/2008 3:13 PM
Works for me !!
Hobbies - CNC - New Member
02/07/2008 12:44 AM
Why all the trouble?
For all practical engineering purposes pi= 22/7 is close enough.
22/7 = 3.1428571
pi= 3.1415927 according to my calculator.
Johan van Niekerk
02/12/2008 9:56 AM
There is a lot more to pi than I thought! All my life I have thought pi was 22/7, the ratio of circumference to diameter! After reading the post, there have been various formula for getting a more accurate pi. They all come back with numbers around the 3.1416 with a few extra numbers after, so how do we actually know what is the true value of pi! My question is, 22/7, was this just a ball park figure thrown at us at school or what?
Just out of curiosity, I punched in 22/7 on the computer calculator and it came back with 3.1428571428571428571428571, it kept repeating the 1428571 sequence! How strange!!
Please remember, maths is not one of my fortes, so be kind
Good Answers: 74
02/12/2008 10:50 AM
Not so strange when you consider that 21/7 = 3, so 22/7 is 3 + 1/7 and 1/7 is equal to the repeating fractional part which you found. You can see why if you do the division by hand. Similarly, 1/9 is 0.11111 ad infinitum.
The value of 22/7 for pi is an approximation which we were given at school, close enough for most purposes but not exact.
Bruce
02/12/2008 1:59 PM
Cheers Bruce, that all made good sense So all the formula above will give different answers when you start getting down to a few decimal points! This throws me a bit, how do we know what is the correct figure for ? Is a formula deemed correct if it gives π to 'n' decimal places? The pi you checked it against, how did you arrive at that figure? Could I state that pi=22/6 to no decimal places? (I would have a 3 to play with!)
I'm sorry if this is Basics for you guys but I have just had to chuck out my old pi!
Good Answers: 74
02/12/2008 5:29 PM
Most calculators have pi on them at the touch of a button. The expression 22/7 is 0.1000402*pi, so it is adequate for nearly all purposes.
Why not say pi = 3 to no decimal places? It's simpler and more accurate.
Bruce
02/12/2008 8:35 PM
(22/7 is 0.1000402*pi - sorry to be picky - but I think you slipped a d.p., there. John.)
Good Answers: 74
02/12/2008 8:51 PM
You are absolutely right JohnDG! I just wanted to see if you were paying attention. Actually 22/7 = 1.000402*pi.
Bruce
02/12/2008 8:50 PM
Here's an interesting little tidbit about Pi:
"it is known that most irrational numbers are
"normal," that is, every k-digit string appears "equally often," for
every positive integer k. (To make this rigorous is possible, but not
quite obvious.)
From these examples, it is clear that not every irrational number is
normal.
It is not known whether or not Pi is normal, although most
mathematicians probably believe this. It is extremely hard to prove
that any particular irrational number is normal. If Pi is normal, then
your friends are right, and somewhere down the line, there will be a
million 2's in a row. In fact, this will occur at infinitely many
different places in the decimal expansion of Pi. If Pi is not normal,
then a million 2's may or may not ever occur."
(from The Math Forum).
-John
02/14/2008 12:00 PM
Cheers again Bruce! I think I'll just sit back and watch the thread! My rainbow book 3 maths will have to do for the moment! I will leave the dilemmas of pi to you guys!
02/12/2008 8:52 PM
Only in Alabama...
02/12/2008 11:17 PM
Good one, JJ.
It's not just in Alabama that the Bible is misinterpreted!
What would happen if someone baked a square pie? Would the universe explode?
S
02/13/2008 6:00 PM
No. PI R not square. PI are round and cornbread R square.
02/15/2008 12:00 AM
R Squared =
02/15/2008 1:09 PM
Good one S.
Here's another take.
Hmmmmm... looks like R Squared = should be Pie Squared =
What's the value of () ^2?
-John
02/15/2008 5:08 PM
Can't do that - but here's √ ...
02/15/2008 6:23 PM
Good one.
Does √Evil = $, or does $² = √(Power)² ?
03/31/2008 11:13 AM
Did you know that Ramanujen had only a highschool education and was working in a post office when he was brought to Trinity College? There was an excellent bio of him on public television several years ago called The Man Who Loved Numbers.
https://enterprise.maa.org/scripts/WA.EXE?A2=ind9910&L=MATH-HISTORY-LIST&D=1&T=0&P=4958
Peace be upon you.
In reply to #60
03/31/2008 11:29 AM
Hi Skelley,
The link you posted redirects to a Myfreeze.com error handling page.
-John
In reply to #60
04/02/2008 6:16 PM
I get a "Certificate error - navigation blocked" message, giving dire warnings about the possible dangers of following the link.
BTW - I think I heard a program about this guy last year on BBC Radio 4. Searching the BBC site gets no hits, but there's a good entry on the U. of St. Andrews site.
Register to Reply 62 comments
ba/ael (11); Brave Sir Robin (2); Johan van Niekerk (1); JohnDG (12); Johnjohn (7); Kris (9); Mr. Truman Brain (3); pwr2thepeople (1); Randall (1); Skelley (1); StandardsGuy (12); user-deleted-1105 (1); user-deleted-9 (1)
