Previous in Forum: Non-Petroleum Microwavable Container Materials   Next in Forum: How to improve the life of spray nozzles
Valve Design and the Physical Properties of Fluids
02/05/2008 11:18 AM
the vales designing process is how much depends on physical properts of any fluids?
Re: Valve Design and the Physical Properties of Fluids
02/07/2008 2:36 AM
02/09/2008 11:19 PM
Q or soliloquy?
Please recompose and submit.
02/10/2008 1:34 AM
Flow Factors
It is clear that different sized valves have different flow rate capacities and it is very important to be able to assess the flow through a valve for a fluid at certain conditions. The flow characteristics for an on-off valve are fixed and can be evaluated directly using the relevant flow factor. The flow through flow control valves, relief valves, pressure reducing valves and check valves depend on the operating condition for the valve and require a more detailed evaluation..
The most general method of identifying the flow capacity of a valve is the Cv factor..
The Cv factor based on american imperial units and is defined as follow
Cv = The flow of water through a valve at 60 oF in US gallon/minute at a pressure drop of 1 lb/in2
The metric flow factor (Kv) is used throughout outside of america and is defined as follows
Kv = the flow of water through a valve at 20 oC in m3/hr with a pressure drop of (1 bar)
The conversion between the two factors is Kv = 0.865 Cv
Also kv is defined as follows...
kv = the flow of water through a valve at 20 oC in litres/min with a pressure drop of (1 bar)
The conversion between kv and Cv is ...kv = 14.42 C v
Liquid Flow
To establish the flow ( Q ) in litres /m at a differential pressure ( Dp )in bar for a liquid with a specific gravity relative to water ( γw ).
Note: This relationship only applies for liquids similar to water at reasonable flows (sub-sonic).
Gas Flow
For gases and supersonic flows more complicated formulae are required....
The formulae below must be used only for rule of thumb estimates. The assumption that the critical Dp is at P1 /2 does not hold for all valves. For accurate flow calculations the valve manufacturers data sheets must be used
For gases flowing at sub-sonic velocities the following relationship holds..
T1 = Inlet gas temperature deg K = Deg C + 273
γa =Gas specific gravity relative to air
q n = gas flow at normal conditions ...
P1 = Inlet Pressure (absolute)
For gases flowing at super-sonic velocities the following relationship holds..
Gas Reference conditions
Normal conditions: P=1013.25mb and T=273.15K
Standard conditions: P=1013.25mb and T=288.75K.
