Previous in Forum: gas pressure regulator   Next in Forum: Converting AC to DC for a micro-hydro turbine
12 comments
Geometry - Its got me Stumped.
02/05/2008 6:43 PM
I came across this geometry conundrum and have passed it around our engineering office.
I think we have considered it from every angle (Excuse the pun) but I just cannot make sense of it.
Worst of all I dont even have an explanation for it.
As I see it, if we agree for the sake of discussion that the squartes are square cm's, then here is my first problem.
Problem 1.
Red Triangle - SA = (8 x 3)/2 = 12 cm2
Green Triangle - SA = (5 x 2)/2 = 5 cm2
Orange block - 7 cm2
Green Block - 8 cm2
SA of the Combined Pieces - 12 + 5 + 7 + 8 = 32 cm2
Actual SA by calculating - (13 x 5)/2 = 32.5 cm2
Problem 2
Total SA second triangle by combined pieces - 12 + 5 + 7 + 8 + 1= 33 cm2
As I understood it,
  1. The total surface area of the parts should equal the total combined surface area.
  2. If you can rearrange the parts to fit inside the same shape, then the surface area should remain unchanged.
So. I just dont get it. Can anyone provide an explanation for this?
Re: Geometry - Its got me Stumped.
02/05/2008 6:50 PM
02/05/2008 6:57 PM
Oh Sorry. Thanks for the direction.
02/05/2008 7:08 PM
I have now read the posts and Thank you thank you thank you.
This was driving me nuts.
02/05/2008 7:05 PM
No problem...
Good Answers: 230
02/05/2008 11:08 PM
Hello Johnoz
Much earlier than the above CR4 listing, this same puzzle was listed in Martin Gardner's column in Scientific American almost 40 years ago.
He had gotten the puzzle from the book written by the great puzzle expert: Henry Ernest Dudeney
I well remember the puzzle, which just about drove me nuts, until I carefully examined and located the interesting solution, after a couple of weeks.
Kind Regards....
02/06/2008 12:01 AM
Cheers Sparkstation.
I knew something was up when I worked out that the SA of the different parts added up to 32 cm2 whilst the overall triangles size was 32.5 cm2.
Its just nice to know.
02/06/2008 11:37 PM
This is the same principle our politicians use the balance our budget. They can't explain it either!
Good Answers: 247
02/07/2008 9:56 AM
A while ago, I cut out the pieces of this puzzle for my kids to play around with. The difference in slope (that makes the long "side"* concave in one case and convex in the other) is subtle enough that even with the pieces in hand and a with a sheet of graph paper to lay them out upon, the illusion is pretty strong.
If you can rearrange the parts to fit inside the same shape, ...
This is the problem -- they are not the same shape: they are two different quadrilaterals.
*Of course this is not really one side in either case -- it is two legs of a quadrilateral.
Good Answers: 70
02/09/2008 12:05 PM
These two overall shapes are not triangles, but are both actually four sided. On each shape the 'hypotenuse' is not actually a straight line. In the top figure it is slightly bent inward where the red and blue triangles meet, and in the bottom figure it is bent slightly outwards.
The slope of the hypotenuse on the red triangle (y/x = 3/8) is smaller than the slope of the hypotenuse on the blue triangle (y/x = 2/5), and as a result they are not actually similar triangles (2/5 > 3/8). They look the same to the eye, but they clearly are not. The larger triangle would need to be 7.5 units long for them to be similar.
If you hold a straight edge (such as a business card) up to the images on the screen, you can actually see that these are not straight lines. This are the kinds of rounding-off errors that can happen when you try to let a piece of graph paper do your thinking for you.
07/02/2008 1:35 AM
In the second drawing. The length of the line segment that is common to both the green triangle and the orange block seems to be 2 units. But this is absolutely wrong!
Note that the green triangle and the largest triangle are similar. Let x be the length of the line segment that is common to both the green triangle and the orange block.
5 / 13 = x / 5
x = 25 / 13 = 1.92
So the second drawing is impossible.
Good Answers: 247
07/02/2008 1:51 AM
Clearly, the second drawing is not impossible -- it is there for all to see.
The largest triangle is the red triangle. The large figure made up of four smaller shapes is not a triangle in either the upper or lower figure. In both cases it is a quadrilateral.
The green triangle and the red triangle are not similar. One is 2 x 5 (hypotenuse slope = .4); one is 3 by 8 (hypotenuse slope .375).
10/10/2008 4:36 PM
In the the first figure: the intersection between the red and dark green triangle does not intersect the intersection of the graph. In the second figure: the intersection between the the red and dark green triangle intersect the intersection of the graph.
Register to Reply 12 comments
Anonymous Poster (1); Blink (2); johnfotl (1); Johnoz (3); kivi (1); Mrgreentoo (1); Sparkstation (1); Steve S. (2)
