Hello from Canada,
A number of years ago I designed an inverter, using an IC from National Semis.
The part number was MM5369.
I wrote to National Semiconductor and I was informed, that this chip is no longer in production.
It is a 17 stage binary divider and it produces a 50Hz or 60Hz logic output. It uses a colorburst XTAL (3.579545Mhz) as a reference clock (very cheap).
If anyone knows of a similar IC (still in production) from any other manufacturer I would be ever so thankful. I have searched the GlobalSpec site and it only gives me the same info I get from using Google.
I don't want to use an obsolete part in a new design.
Thanks
Jens
