Previous in Forum: re: button-pushers..   Next in Forum: design and performance of hydraulic ram pump
10 comments
Low friction Free spinning two axis Gimbal Mount
02/06/2008 7:52 PM
I've been searching the internet for a low friction free spinning two axis Gimbal Mount that I can mount small electro-magnet experimental packages on. Obviously the mount must be non metallic.
Alas, I can find nothing that looks like it will work. Does anybody have any ideas?
Gavilan
Pathfinder Tags: Gimbal Mounts
Good Answers: 143
Re: Low friction Free spinning two axis Gimbal Mount
02/07/2008 8:52 AM
Are you adverse to making your own? There are glass bearings aplenty. Got any details you can share?
Good Answers: 918
02/07/2008 4:08 PM
How about an old aircraft ADI? They are sometimes called the ball or artificial horizon.
You can buy those on eBay, but there probably some steel in the bearings.
02/07/2008 11:49 PM
I would try a clockmaker/repairer or a marine supplier. Both Chronometers and ship's
magnetic compasses are gimbal mounted.
There may be something in an ex military surplus store
02/08/2008 12:05 AM
Also Astronomers models and some globes. Marine compasses can also be fluid mounted which might be another option for you if you only require two axis. Go to some markets, their are Indian (from India) people that make and sell what you require. a Jeweller or Clockmaker could give you jewelled bearings.
Good Answers: 109
02/08/2008 4:14 AM
Hi,
there are two more possibilities if you can live with limited freedom of the gimbal mount:
a.: an air-bearing made from a hemispherical stator and a spherical rotor.
open halve of the hemisperical stator vertical up,
spherical rotor with a small diameter shaft protruding from the sphere, so that the rotor can be used with tilts up to 75°,
airbearing supplied with compressed air and a small nozzle at the center, the nozzle
can be exchanged to a porous restrictor or to a partial grooving of the stator or
rotor.
Difficult to build but very good in very low friction.
b.: second possibiliy is a flexure hinge, long time ago made bey Bendix then Teldix
now Lucas. We made ours much more precise (monolithic) by wire edm from a
solid piece of high quality metal.
The gimbal of this monolithic two axis flexure hinge is moving in a complicated
manner at rotation of the hinge about its axis of symmetry. This movement has
components that act as a negative flexure. So there is a speed where the positive
stiffness of the flexures is canceled by this inertia-induced negative flexure.
These hinges are used in a gyro (named dry tuned gyro) for inertial navigation and
gave a major breakthrough in the 70ies.
In the foto you see the two hinges of one axis (the rear one only shadowlike) the
two hinges of the second axis are not seen, the second axis is perpendicular to the
first axis and to the axis of symmetry.
You can glue from thin flexures and rigid parts a first approach.
RHABE
Canada - Member - New Member
Good Answers: 11
02/08/2008 6:03 AM
You may want to have better quality than this cup holder, perhaps if you have some design and machining capability you may be able to build one using model aircraft parts like clevis and hinge tape or use more industrial plastic components bearings and rod ends.
If it is just a quick test jig you need, using ABS or PVC tube form your hardware store and some pins should let you build one easily.
02/08/2008 9:19 PM
A Dead Weight Tester may be used if you have the right type.
Raz
02/09/2008 10:00 PM
No, its NOT obvious that it must be non-metallic! I does sound like it needs to be non-magnetic, but unless your magnets are moving rapidly, in which case they might generate excessive eddy currents, there are plenty of non-magnetic alloys available.
Since you mention low firction, bronze come to mind...
02/10/2008 2:59 AM
Size matters....
If you are looking for a small size mount you can make your own by nesting one slice of PVC pipe inside another and drilling for axle mounts. Bronze bushings for bearings are a good non-magnetic choice for a DIY. Which just leaves the pins. glass rods would be a pretty good choice there. A press fit sized hole for the mount and drill out the bearing side for the bushing. Good luck on with you searching otherwise.
02/10/2008 10:55 AM
Thank all of you for taking the time to reply to my question. It was generous of you to share your ideas.
Thank You.
Gavilan
Register to Reply 10 comments
Anonymous Hero (1); Anonymous Poster (3); dkwarner (1); Gavilan (1); gigaconcept.com (1); Raz (1); RHABE (1); TVP45 (1)
