Well the first part seems straightforward enough, add up the combined loads and throwing 25 to 50% for Murphy or expansion. "A good engineer is a wee bit conservative at least on paper"
1. Vpu = v
IM just kidding, found this link while I was trying to figure out exactly what you were talking about, I hope it will be of some help. However your use of the word minimum is scary, I'm not kidding about Murphy leave enough to cover him.
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore all progress depends on the unreasonable man" George Shaw
thanks for this cocern..bt i know per unit calculation ..i need exact method for calculating the rating of any transformer and its percentage impedence...
Now I am curious to, I had assumed you were looking to set up multiple transformers, i.e. production facility. If you can provide a little more information about your application it might be helpful.
PS I had read Read a couple of posts when I responded. Somehow I was thinking you were looking for the minimum requirements, to feed multiple transformers.
