Previous in Forum: Need of Answer   Next in Forum: Transformer Calculation
Cable Calculation
02/08/2008 6:21 AM
pls tell me the cable size calculation in for HT lines. include short circuit condition
40ka for 0.16 sec.bye giving example
pls
Re: Cable Calculation
02/09/2008 7:35 AM
Dear Friend,
Your general and wide question will have a general and wide answer. Please explain the matter specifically. What is the voltage level? What is load parameters? What is the cable laying type, ambient temperature, grouping factor? Which standard and code is applicable for the project? What is the cable insulation, EPR, PVC or XLPE? and ....
A thousand-mile journey begins with the first step.
02/10/2008 1:28 AM
ok
take the data
3.3 kv votage level
40 KA for .16 sec short crcuit current level
500 kw,860 kw motor ,derating factor take 0.69
cable shuld be AL XLPE
LENGHT IS 300 METER
POWER FACTOR .85 EFFI. .85
CABLE SHULD BE OF THREE CORE
PLS SHOW ME THE FULL PROCEDURE OF CALCULATION SO I CAN DO FOR OTHER MOTORS
02/10/2008 6:10 AM
The cable sizing has the following sequence.
This calculation is only for reference, you should study related national codes and standards and also refer to cable manufacturer technical catalogues.
1-Calculation of Load current:
In=P/(√3*VL*PF*Eff.)=860/(1.732*3.3*0.85*0.85)=208A (for 860kW motor)
2- Short circuit withstand current of cable (IEC Standard):
Min. cross sectional area for Aluminium conductor, XPLE insulated cable
Smin=Icc*(√t)/k= 40000*√(0.16)/94=170.2 mm²
You should also check the shield and armour current capacity for earth fault currents if applicable
3- Permissible voltage Drop value (Operation: <5% and Starting <15%)
ΔV%=√3*In*[(R*Cos(φ) +X*Sin(φ)]*100/VL=1.732*208[R*0.85+X*0.53]*100/3300 R and X shall be extracted from MFR's technical catalogue
3- Current Carrying capacity of cable by considering all de rating factors such as ambient and grouping factors shall be > 208A
02/10/2008 11:08 PM
THANKS UPTO THAT. BUT
HOW WILL U SELECT R AND X VALUE .(WHAT BASIS FOR SLECTING R AND X)
02/12/2008 1:21 AM
You don't select R and X. R is the active resistance and X is the inductive Resistance of selected cable. The value of R and X is to be extracted from cable MFR's technical catalogue or related standards.
For example: Manufacturer: EUPEN, 3-core, Al/XLPE, 240mm²
the active resistance(R) at 90ºC is 0.166 Ω/km and inductive resistance(X) is 0.105 Ω/km and the short circuit withstand current for 0.2 sec. is 50kA.
02/13/2008 7:53 PM
The biggest concern in MV cable sizingis always short circuit. Hence you must have sufficient knowledge of the protection device above the cable. If it is a Breaker, you need to check how many cycles are required for tripping on a fault. Then leave sufficient margin and then calculate the cable size. If it is a Fuse, check the characteristics; hopefully the fuse will operate in less than half a cycle, which will drastically lower the cable size. Next comes ampacity. Voltage drop is never an issue in MV\HV where currents are low and cable sizes are high. Hence, strictly, the order for MV cable sizing is :
Short circuit...........AMpacity...........voltage drop
02/25/2008 2:13 AM
ok how we use derating current in the cable selection
Register to Reply 7 comments
Abbas (3); admire_azit (3); Anonymous Poster (1)
