HELLO to all hope you can help
I am trying to fix my friends little MIG welder. it had one button rectifier burned out so i ordered new ones and replaced them all.
but there is a loud hum and if trigger is held on it blows the circuit breaker in the house.I called lincon repair they told me to disconnect the relay and hard wire past it still hums they had no more help so i figured I would let some real brains try to figure it out is there any way to test transformers for internal shorts as to ohms as i tried to ground and to high to low legs no short as far as i could tell with diode tester and dvmm
