Previous in Forum: 80:20 analysis   Next in Forum: Elbow Forming Machine
aluminized pipes (aluminium coated inside and outside)
02/09/2008 9:09 AM
Dear Sirs,
I couldn't find aluminium coated pipes (both inside and out side)to use for exhoust
systems.I will bend them with small radiuses.They must stand for 480 hours salt spray test.I get some samples from
Italy and chine but they did not give sufficient results about oxiding.If you know
where can I find this kind of pipes please give me their adress.Thanks in advance.
kulpedin@teknikhortum.com.tr
Re: aluminized pipes (aluminium coated inside and outside)
02/09/2008 11:10 PM
Do your plain Carbon Steel pipe fabrication:
Sandblast ID/OD
Batch Aluminize in your Thermal chamber.
Requirements are low.
Steel tube makers do not offer as regular commercial item
Good Answers: 16
02/10/2008 10:49 AM
I would instead recommend 316 stainless steel tubing for your salt environment application.
Regards, Delmar Schmidt
Melfi Technologies Houston
www.melfitechnologies.com
Specializing in Dynamic Weighing Systems for Powder and Bulk Solids Handling
02/11/2008 10:20 AM
My good buddy Sherm. Jet-Hot baby!!!! The rest is history.
"I had not anticipated that the work would present any great difficulites" SHACKLETON
Delmar (1); MUKULMAHANT (1); NiCrMoNoMore (1)
