WWTP's in CT must still reduce nitrogen as much as possible, winter notwithstanding. Very few plants are indoors or covered. It is recognized that plants are less successful at removing nitrogen in cold weather. Running with a higher solids content in winter is one way of "tweaking" the process. I am looking for other possibilities. Actually, heating mixed liquor is not a bad idea. I'm just not sure how to go about doing it: are there such things as submersible heaters?
Water hyacinth treatment system using a greenhouse is one method.
The optimum wastewater temperature range for nitrification is between 60 and 95 degrees F. At low ww temperatures, five times as much detention time may be needed for complete nitrification.
Compensation for lower winter growth rates (of nitrifying bacetria) are necessay by increasing the MLVSS concentration, the MCRT, and adjusting pH to favorable levels. These methods can be expected to provide substantial if not complete oxidation of ammonia-nitrogen compounds.
What form is the N2 in? If it is in NH3 form, very vigorous aeration can remove it. If it is in NO3 form, heating the water to stimulate the activity of bacteria to denitrify it or the use of plants in a heated environment will also work.
This process is called denitrification. Nitrification converts ammonia to nitrite and nitrite to nitrate and that's it. Denitrification converts nitrate to nitrogen gas. This is done in the anoxic zone of an oxidation ditch or by the Bardenpho four-stage process.
If the process train is such that no carbon is present in the denitrification reactor, then methanol will have to be added. This will be expensive.
