Previous in Forum: Wastewater Technology in New England, USA   Next in Forum: Bio Diesal
Walnut shell & Water Filtration
02/11/2008 6:08 PM
We are looking for water filtration units that use 'walnut shell' If you know of any, please let us know @ rebecca@ecoshell.com
Australia - Member - New Member Hobbies - Target Shooting - New Member Popular Science - Weaponology - New Member
Re: Walnut shell & Water Filtration
02/11/2008 7:13 PM
Not knowing the breakdown rates for Walnut shells, I would look at using them as a substitute for a Sand Filter.
Or for aquariums something along the line of "Bio Balls" where surface area is the key requirement. These become the base for an algae that eats amonia and oxygenates the water for the fish.
Sapper
It's all about the Boom! - MythBusters
02/12/2008 12:32 PM
The Walnut Shell is used in Deep Bed Filtration applications to remove heavy metals and oils.
The application for fish aquariums would not be healthy because the shell has tanic acid.
12/05/2008 12:58 PM
Do walnut shells have any trace insecticides or herbicides such as arsenic or cyanide?
whats the concentration of tanic acid?
phoenix911
12/05/2008 2:01 PM
Walnut shells do not have any trace insecticides or herbicides such as arsenic or cyanide in them. They are all natural and we clean them in our grinding process. As far as tanic acid goes, the amount has never been measured, but it does wash off eventually.
Rebecca
12/05/2008 1:58 PM
Walnut Shell is used as a substitute for sand filters. Sand has silica in it and is not an acceptable product as 'green'. Walnut shell has been used for years in filtration units. It is also excellent for mold. There are several articles on the internet, just put in 'walnut shell vs mold' and you will see.
Rebecca
02/13/2008 5:59 AM
Crushed and carbonised nut shells can be used to make granulated activated carbon [GAC]. GAC is widely used in the water treatment arena for removing tastes, smells and oxidising agents such as free chorine from waters prior to further processing, or for drinking. There are large numbers of suppliers worldwide. Local suppliers may be found anywhere from the commercial section of the telephone directory to internet search engines.
A replacement under-the-worktop carbon filter for treating 2000L of water for use in the kitchen can be had from on-line suppliers for less than £10GBP.
Register to Reply 6 comments
phoenix911 (1); PWSlack (1); rebecca7 (3); Sapper (1)
You might be interested in: Industrial Filtration Equipment, Filtration Media
