Here I am again with another Microsoft Access problem. Solved the previous one with CR4 help - how about this? I built a database years ago, & the command button wizard worked great. I build a database today, & the command button wizard works great. But a database I built last year cannot make a command button work (wizard or no) unless I attach a macro. The wizard seems to work, until I return to form view, depress the command button, and NOTHING happens. Why? Have I unknowingly turned off a switch that keeps a command button from running when established by the command button wizard? Any suggestions?
