Previous in Forum: Looking for a Good Outdoor Plastic.   Next in Forum: Searching for a metal to OSB contact bond adhesive
9 comments
What Label material resists steel abrasion from guitar strings?
02/11/2008 1:55 PM
I'm looking for an permanent adhesive label material ( or?) that may be imprinted with a design and will resist abrasion from steel guitar strings. The application will be applied by consumers to guitar neck fret boards (typically rosewood) and in the manufacturing process of guitar neck fret boards as an applique. Please advise.
maxirobere@gmail.com
Re: What Label material resists steel abrasion from guitar strings?
02/11/2008 2:28 PM
A clear plastic printed on the reverse... polycarbonate maybe?
Good Answers: 66
02/11/2008 3:00 PM
Polycarb would be my suggestion as well. 3M has an extensive line of silk-screen-able, self-adhesive PC labels.
Aequam memento rebus in arduis servare mentem.
Good Answers: 918
02/11/2008 7:07 PM
What text will you be putting?
02/11/2008 7:48 PM
various image and/or text will be imprinted. Why would it matter?
02/12/2008 10:22 AM
I've played guitar for many years and have worn many rosewood fret boards down! My Guild is in a bad state at the moment with some pretty deep worn patches! I think the placement of the sticker is important too! Where are you going to position them? I don't think any sticker would last too long within the first 16 frets whatever the plastic!
02/12/2008 10:36 AM
Find a local label Mfg. and ask for a 3 mil thick polyester, or at least 2 mil thick. The label should be printed and next a clear adhesive transfer tape added to the printed side with a release liner and die cut to your shape. Your final label will have the printing protected with a top quality clear polyester film absorbing the abrasion.
02/12/2008 10:41 AM
And while you're at it, ask for the frets to be made taller!
02/12/2008 11:52 AM
Isn't the rosewood treated with some kind of oil to preserve it and prevent it from drying and cracking? I would think you'd be hard-pressed (sorry) to find a sticker that would reliably adhere to an oiled wood. If your market is in new guitars, you could make a solid plastic fretboard with plastic inlaid designs so that the color runs the depth of the fretboard. That way as the plastic wears (and it will) the design will remain.
United States - Member - I am a Yankee Doodle Boy. Engineering Fields - Manufacturing Engineering - Old School is the best school. Safety - ESD - Safety Mgr that keeps the peace Hobbies - DIY Welding - My Motto:
Good Answers: 26
02/12/2008 4:36 PM
Hello interjecting here just a bit.
When we are manufacturing a decal here the we want to hold its appearance we do what has been suggested previously. We use a durable material such as a poly carb or polyester. We print on the back so the print shows through the material and then apply an adhesive to the material over the ink to adhere it to whatever so the print shows nicely.
The materials will all wear about the same when using a clear as scratching will occur on all of them. Even the best of poly carbs.
As far as adhesives go there are many that will stick in the most adverse environments. However I would suggest that if you want them replaceable then you might want to consider a less aggressive adhesive and one that is promoted as a removable and not permanent.
If necessity is the mother of invention then is laziness the mother of necessity?
Register to Reply 9 comments
Anonymous Hero (1); CSM Engineer (1); double_j_b (1); Gary King (1); maxirobere (1); Mr. Truman Brain (2); user-deleted-1105 (1)
