Previous in Forum: Stainless Steel 316, Magnetic?????   Next in Forum: TUBES 1045 OR DIN 1629-ST52
Wastewater Neutralization
02/13/2008 5:55 AM
the textile wastewater pH is 13, for the pH is reduced to pH 6 .5 by using sulfuric acid.
How do calculate the dosing rate of the sulfuric acid.
Re: wastewater neutralization
02/13/2008 6:11 AM
Using the concentration of the alkaline species present and the stream flowrate, do a mass balance on the sulphuric acid addition process until all the alkaline species is converted to its sulphate.
Check the discharge consent conditions imposed by the local environmental authority. Discharge consents are usually in a band. So if the consent is pH 6-10, for example, then the economic setpoint for discharge is pH 10, though it may prove wise to operate a little under that figure.
Re: Wastewater Neutralization
02/13/2008 1:48 PM
Is this batch or continuous feed?
All this worldly wisdom was once the unamiable heresy of some wise man. -Thoreau
02/18/2008 2:29 PM
the OH concentration at pH 13 is 10^-13 molar
at pH 9 is will be 10^-9 molar
the difference (approx 10^-9M) is the amount of equivalents of acid you need to add
sulfuric acid provides 2 equivalnmts per mole and is 96% pure as bought and used
use the MW of sulfuric and the volume of water to be treated to complete the estimate
this is only a rough estimate - you really need to do a titration curve with your wastewater
Steve
Anonymous Poster (1); Ben Bonsens (1); PWSlack (1)
You might be interested in: pH Electrodes, pH Transmitters, Lead Acid Batteries
