can you give me desin circuits of electric of pcb easy with use simple
komponen and must use sensor? that's my question please help me because
this is my final exam in college?
Hmm, the final exam for your class is to develop a circuit diagram, likely based on a semseter's worth of study. Instead of honing your skills and doing the work yourself, you just want someone on a forum to give you a design? How does that help you to learn this material? And more to the point, why would any of us want to help an untrained engineer get a degree and to enter the work force...
DO YOUR OWN HOMEWORK!
Just like regular Elvis...only smaller.
In your situation you should consider a "electronic" project you had at school when you were ±10. The one with the battery, switch and bulb should do fine.
If that is still too complicated you may replace the switch with a thumb tact and a paper clip.
