Previous in Forum: Torque values with bolt coatings.   Next in Forum: Cold Pull Piping
Valve Handle Orientation for Flare Header
02/13/2008 6:53 AM
What would be the Valve Handle Orientation for Flare Header Lines at Battery Limit?
What is the Reason?
Re: Valve Handle Orientation for Flare Header
02/13/2008 8:45 AM
What did the HazOp Study report say on this subject?
02/14/2008 5:34 AM
Cause & Effect and HAZOP are required.
02/14/2008 9:06 AM
I am an engineer in an oil refinery.
We have the requirement that gate valves related to safety relief lines be mounted with the stem horizontal.
This is so that if the disc would become detached from the stem it would not fall and block the flow path.
Good Answers: 61
02/14/2008 9:06 AM
You did not give us some of the important information with which we would use to give a proper answer. So I will make the following assumption.
The valves are Gate Valves. Right?
The orientation you are talking about is the orientation of the "Stem" of the Gate valve not the hand wheel itself.
If so then my answer is:
"All Flare system Gate valves SHALL be installed so the Stem is in the horizontal position (never vertical)."
The reason for this is an age old fear that when in the vertical position the disc (of the gate valve) might come free from the stem and fall down to the closed position. If that happened then sure enough there would be a huge relief event and the flare would be blocked.
We all know that Gate valves are designed somewhat different today than they were 75 to 100 years ago and few if any would have this problem but the horizontal only practice persists.
This "Rule" does not effect the stem orientation of any other type of valve (i.e.: Ball, Plug, Orbit, etc.).
Do it once and do it right
Abdel Halim Galala (1); Anonymous Poster (1); PennPiper (1); PWSlack (1)
You might be interested in: Video Cables, Cable Assemblies, Serial Cables
