Previous in Forum: Cold Pull Piping   Next in Forum: Heat Spreader Material
positioning louver
02/13/2008 8:57 AM
I am looking for louvers that are motorized and can be controlled for positioning. Can someone recommend a supplier in USA. They will be installed in the ceiling and wall of a building.
Location: Lenox, Massachusetts, United States of America
Re: positioning louver
02/13/2008 12:41 PM
Are these louvers to keep the sun out? To control air flow? Is there some other use that you have?
What kind of material might work best for you? Is there some idea as to the size, weight or other physical properties that you can share?
More information will help.
In the meantime, click here for information from The Engineering Web(r).
WM
02/13/2008 1:10 PM
we are controlling air flow in and out of a room. The ceiling mounted louver is to be 48" x 48" and the 2 wall mounted louvers are to fit in 2- 36" x 36" openeings. They can be any material that will last. We will control them with a temperature controller.
Maximum CFM through the 48" louver would be 5000. Divide that for the 2 36" which will be inlets.
Register to Reply 2 comments
