Previous in Forum: Cold Pull Piping   Next in Forum: TACT
Valve Handle Orientation for Flare Header
02/13/2008 11:49 PM
What would be the orientation for Valve Handle in Flare Header Line at Battery Limit?
and what is reason?
Good Answers: 61
Re: Valve Handle Orientation for Flare Header
02/14/2008 10:16 AM
You did not give us some of the important information with which we would use to give a proper answer. So I will make the following assumption.
The valves are Gate Valves. Right?
The orientation you are talking about is the orientation of the "Stem" of the Gate valve not the hand wheel itself.
If so then my answer is:
"All Flare system Gate valves SHALL be installed so the Stem is in the horizontal position (never vertical)."
The reason for this is an age old fear that when in the vertical position the disc (of the gate valve) might come free from the stem and fall down to the closed position. If that happened then sure enough there would be a huge relief event and the flare would be blocked.
We all know that Gate valves are designed somewhat different today than they were 75 to 100 years ago and few if any would have this problem but the horizontal only practice persists.
This "Rule" does not effect the stem orientation of any other type of valve (i.e.: Ball, Plug, Orbit, etc.).
Do it once and do it right
02/20/2008 2:06 PM
Make the valve handle orientation match the flow. If the valve is open, the handle should be parallel over the line. When closed, it should be perpendicular.
08/22/2024 7:47 AM
Question the need for the <...Valve...>.
Register to Reply 3 comments
Anonymous Poster (1); PennPiper (1); PWSlack (1)
You might be interested in: Video Cables, Cable Assemblies, Serial Cables
