Previous in Forum: Need NDT course   Next in Forum: speed limiter for playground
Piping : Pipe Rack connection for Different Settlment of Process Section & Rack
02/14/2008 5:37 AM
Piping :
We have a issue of different settlement issues of process plant & connecting piperack.
Process plant will settle in ground uniform from 3" to 6" where as pipe rack will settle 1" in ground.. ...
We have a problem that how to adrees the issue of different settlement while connecting piping from pipe rack to process section & back.
We request advice for the same.
Best regards
Shekhar Sali
Re: Piping : Pipe Rack connection for Different Settlment of Process Section & Rack
02/14/2008 3:30 PM
lower the rack 10" and use a spring system
02/14/2008 11:02 PM
Make final connection to the plant with 6 foot long sections of flex hose rated for the duty requirements. It works great.
02/14/2008 11:15 PM
Hi, Thanks for the advice.. We have a line sizes from 1" to 30" sizes ( CS + SS )...
For higher sizes flexi hose may not be suitable. We are thinking of providing Slip type expansion joint..Can you advice?
02/15/2008 6:13 AM
A good piping designer will allw for a number of bends and expansion loops to be present in the piping runs so that the incoming piping will bend, twist and flex to suit differential movement over time. It is to that individual that the problem needs to be presented.
Bellows are good for making connections in rigid pipe flexible, though these need to be correctly supported at design stage. Beware, and please read the following story:
http://en.wikipedia.org/wiki/Flixborough_disaster
Hobbies - DIY Welding - pipewelder
Re: Piping : Pipe Rack connection for Different Settlement of Process Section & Rack
02/15/2008 6:59 AM
I am not sure how you can get so much different settling if you are constructing everything according to your specs. Don't you all use foundations and pack the dirt before building on it? If you are dealing with 30" pipe you may have to wait till everything settles and then refit the pipe drop from the rack to allow for the settling. I don't care much for the really big slip joints on a system that has allot of pressure or contains hazardous materials cause they tend to leak and are usually high priced. Most steam lines are designed with built in loops that give enough to compensate for the thermal expansion. On the bigger pipe sizes this is near impossible to do unless you have allot of extra room and again a bunch of money. one thing you can look into would be to use wedges and blocks to shim the under the pipe as the process structure settles and install spring hangers on the pipe rack side. If you can gradually shim the pipe up as the structure settles over a long run of pipe the induced stress may not be so great as to harm the pipe.
pipewelder
pipewelder
02/15/2008 7:18 AM
Hi,
Thanks for the advice, surely will think over it.
(As soil is having very low bearing capcity .. precess section is mounted on Raft with piling..expected settlement 3-6" for process section & Rack 1"..)
80% settlement is expected in ~3 Months after complete loading / erection & 100 % expected in 2 years of span..Just for your information
Thanks once again..
Good Answers: 97
02/16/2008 3:30 AM
Hello,
The issue is load bearing area of the raft foundation, a correction of the load bearing area is needs to correct the disparity of settling vice versa.
Register to Reply 7 comments
Anonymous Poster (4); bwire (1); pipewelder (1); PWSlack (1)
You might be interested in: Piping Services, Piping Systems, Rack and Pinion Gears
