Previous in Forum: CT Sizing   Next in Forum: Does a 110v DC System Consist of Power Factor?
Enegry Meter Calculation
02/14/2008 6:25 AM
If i have KWH reading from the meter & i know the multiplying factor then how do i calculate the units.
does there should be a difference of unites between my calculation & meter calculation???
Pathfinder Tags: Enegry meter calculation
Re: Enegry Meter Calculation
02/14/2008 6:43 AM
" ... how do i calculate the units."
What units?
02/14/2008 6:52 AM
In the UK, domestic premises are billed by kWh consumed. 1kWh = 1 unit, for charging purposes. So the multiplying factor is 1.
Good Answers: 61
02/14/2008 9:31 AM
Most KWH meters contain either a shunt or a current transformer, so that the recording unit only sees a portion of the actual load.
Calculate energy usage as follows:
02/14/2008 10:19 AM
Surely, if the meter says "KWH", it means it? Otherwise, it should say something like "Energy in arbitrary units - use conversion factor to calculate KWH" - or have I missed a point, here?
Good Answers: 61
02/14/2008 11:36 AM
For modern electronic meters, you are correct. For electromechanical meters, unfortunately, that's not always the case.
The recording section (the gears from the induction disc to the dials) are a standard design, regardless of the size of the electrical service. The display register (dials) are likewise a standard design, and read directly The coils which drive the disc are not designed for full line current (if they were, they wouldn't fit in the glass envelope). CT's or shunts are used to reduce the input current to (usually) 5A full scale. Using a 400:5 CT on a 60A service would not yield the required accuracy for revenue billiing, so different CT's are used depending on the type of service. PT's may also be used if the service voltage is over 600V.
The display register shows the total KWh seen by the recording section, but that's not necessarily the same as the energy through the entire service. The meter multiplier is the product of the CT ratio and PT ratio.
Section 4.2 of the this training module gives a good explanation (actually, the entire module is a good primer).
03/21/2008 12:48 AM
how to calculate CT ratio
02/14/2008 11:02 PM
Hai,
Basically there are 2 types of meters.
1)Analog meters(Consists of Electromechanical arrangements)
2)Digital meters
KWH is KILOWAT HOUR. For ONE unit requires 1000 revolutions of the alluminium disc which causes the increase in the numeric value such as one unit.
Register to Reply 7 comments
Anonymous Poster (2); JohnDG (2); pwr2thepeople (2); PWSlack (1)
