Previous in Forum: Filter for glycerin   Next in Forum: dry curing
14 comments
adhesive curing light alternatives
02/14/2008 7:21 PM
I need to recieve some informative information from someone with the knowledge.
I resently purchased a ceramic polymere light cured product that I am tring to find an alternative light sourse for curing it. The product comes in many different colors in which there is one type of light source that is suppost to curing them all. The only problem is, I can not get info from the company about what type of light cures their products ( their trade secret because of the price they are asking ) which I find $2,000.00 dollars a bit hard to swallow. I have done some investgating and have found out that a blue UV dental curing light will cure them but, not all the way because, the hand held light will only stay lit for 60 seconds and I don't want to burn the element out for production work. I also have found that a $21.00 dollar black light will cure the darker colors but not the lighter ones.
I know the Dental hand held curing light I am using is in between the light spectrum of 360nm- 550nm's. I think I could use this spetrum range to cure the product to it's full capacity if maybe I knew of a type of light box that emitted the same nm's that could handle longer running times?
Please help!!
Thank you very much, Mark/ Hemihi
Canada - Member - New Member
Good Answers: 11
Re: adhesive curing light alternatives
02/15/2008 12:37 AM
Looking thru the product MSDS may help you identify the chemistry and you could compare their chemistry to other processes.
You will probably need a shorter wavelength source than the dental light you tried, these can be expensive, depending on the power density you need. The energy density may need to be quite high since you have a lot of solids in your solution.
5-6KJ/cm2 between 200 to 400nm is possibly in range for speed curing.
This site is quite full of free info: http://www.specialchem4coatings.com/index.aspx
Try ebay
Before you need to make sure you are wearing appropriate protection for your eyes and skin.
Here are some other possible technologies and tinkering you may try:
Deuterium lamps
Xenon lamps (Possibly a powerful photo flash or stroboscope with the UV filter removed)
multi chip LED's down to 230nm
Mercury lamp
Tanning lamp
02/15/2008 10:25 PM
Thanks for your input and advise Gigaconcept. I have not tried to get the MSDS from the company yet but, will try that first. The links that you supplied have been very helpfull. I will try looking on E-Bay also.
Thanks again.
Good Answers: 11
02/15/2008 11:04 PM
It is a pleasure to help.
Can you disclose the company who manufactures this product?
Good Answers: 109
02/16/2008 9:27 AM
Hi Gigaconcept,
5-6KJ/cm² - if deposited as flashlight - will melt down steel surfaces.
So may be it should read mJ?
Is this thought as the lamps power x time or is this only the UV-B part of the spectrum?
Some ordinary lightsource that certainly will work for a test is a TIG welder.
But be very careful to protect your eyes and skin!!!
RHABE
Good Answers: 11
02/16/2008 9:39 AM
This an exerpt from the paper liked.
This is a ceramic printing and curing research project, perhaps not applicable for metals or plastics.
02/16/2008 9:44 AM
02/16/2008 3:11 PM
Dear, Gigaconcept,Rhade,and gumb17jb,
Maybe I should give you a little more info to come up with some answers. Being a Dinosaur in the way of using Forums please excuse me for seeming a little vague.
The Company's name is "Heimerle- Meule" in Germany and they offer a product to the jewelry trade named Colorit. If you buy their products they sell lights to cure them. One such light is a hand held and the other is a type of small light box. It is mainly used for coating gold and silver as an alternative to High fire enamel which is basically glass melted onto 18K gold or better.
From my short expereince with the product, without using their lights to cure it; a basic Black light will somewhat cure the darker colors but , not the lighter ones. I have used a Dental hand held blue UVB light and it will cure both but, not to it's full hardness. I am told that once it is totally cured you should not be able to scratch the surface but, I can which leads me to believe it's not being cure properly with these methods of curing lights.
Also, the pieces being cured should be placed into Glycerin to cure the oily smear layer left on the surface after the colors cure or you end up with a matt finish on the surface to be polished. It seems easier to cure it in Glycerin and knock a step out because, it is very time consuming to polish.
I hope I have given a little more info for all of you to work with.
Once again thank you for all of your imputs, it has been a great help in my knowledge. HemiHi
Good Answers: 109
02/16/2008 4:24 PM
Hi Hemihi,
if you have a look at the website of the company you will find the data for a pure thermal cure of these "colors".
I suppose that these materials consist of a polymer that is filled with hard and colored mineralic or ceramic particles.
RHABE
02/17/2008 10:22 AM
Your use of a dental light means your target is small.
We bought a very simple toaster oven then punched a hole in it's top for a halogen lamp socket. We chose a 600 watt, 120 volt projector bulb. Put an aluminum foil reflector under the target. Total cost was maybe $100. It cures fast and it heats. We use it daily and the $15 bulb lasts a year.
Bob G
"If we all worked on the assumption that what is accepted as true is really true, there would be little hope of advance." -- Orville Wright
02/17/2008 4:17 PM
Hello Rhabe and BobG,
First Rhabe- I looked on the companies web site and the only thing I saw was "Intense Blue Light" for curing Colorit products. Maybe I just couldn't find "Thermal"? So is what your telling me is, it can be cured by just a Halogen high watt light bulb that will put off some degree of heat (no blue light like UVB needed)?
Second BobG- The Toaster Oven sounds great! Should it be my understanding that this device that you made and use cures this "Colorit" product?
Thank you all, Mark
Good Answers: 11
02/18/2008 10:16 AM
Halegen lights do have a fair amount of UV in their spectrum.
It is filtered out for regular lighting.
In UV curing lights, the IR and Vis part of the spectrum are filtered.
My Translux EC dental curing source uses a EFR64634 15V 150W halogen lamp.
If you look at Osram ,GE, you will get line powered lamp datasheets with unfiltered UV output. Not much is on their sites, you may need to call.
Good Answers: 94
02/18/2008 6:11 AM
Lots of people make UV curing lamps, shop around. Some will let you try before you buy, others will evaluate a sample of material that you send to them.
http://www.dymax.com/products/curing_equipment/
http://www.jentonuv.co.uk/
http://www.primarc.com/
http://www.alpha-cure.com/
03/08/2013 1:20 AM
the curing light on the market mainly consists of two types according to the difference of light: the light is white and the blue light.
i found this site they provide many reasonable price for dental curing light hope this will help you.
05/14/2015 4:50 AM
I bought a Dental Curing Light last week, xlite II Curing Light Widen Wavelength LED,anybody heard this?
Register to Reply 14 comments
Anonymous Poster (1); bobguz (1); gigaconcept.com (4); gumb17jb (1); Hemihi (2); maxdentalsupply (1); Nigh (1); RHABE (2); wfsjjh (1)
