Previous in Forum: electrical   Next in Forum: Let's talk more about PF...
APFC panel
02/15/2008 12:06 AM
In LT system we can improve the pf by providing a APFC panel..In HT how it will work??
Re: APFC panel
02/15/2008 8:03 AM
U can put the question in a better clear and specific way!
Re: APFC panel
02/15/2008 10:52 PM
Hello Ranju,
It will work exactly the same as it works in LT.
The principles of power factor correction will not change, the capacitors will be rated to the operating voltage.
I hope this helps.
Good luck.
He must be very ignorant as he answers all the questions he is asked. Voltaire
Good Answers: 19
Re: APFC panel
02/17/2008 1:03 AM
I would like to elaborate little bit on this.
In LT system(say 415 V) ,CTs will be located in the Main Power Distribution panel.CT connection and potential connection will be given to Automatic Power factor correction relay.(APFC relay ) this relay willbe of 4/6/9/12 stages).supposing 4 stages means there will be 4 banks of capacitors located in the Capacitor panel and controlled by a contactor.The contactor will be located in the same panel.The contactor will get signal from APFC relay for switch on /off depending on the PF of the load.
For HT system the method would be same, but instead of Contactor controlling unit would be VCB or sf6 breaker.the capacitors will not be located in the same switch gear panel.CT and PT will be located else ware for giving detailed current and voltage input to APFC
Ramesh,Freelance Electrical/automation Consultant
Re: APFC panel
02/29/2008 4:07 AM
TCSC , thyristorised control Series Compensation, a circuit where switching of capacitors are thyristorised controlled. Normally used in transmission line. You can check web site to learn more on this topic.
BNDas
India - Member - New Member
Location: 5/29, Sivalingam Pillai Layout,S.V. Mill Post,Udumalpet- 642 128Coimbatore DistrictTamil Nadu - South India
Re: APFC panel
03/06/2008 6:09 AM
Dear BISWANATH
WE are intrested only in conventional type , LT 690 V ac only please reply for this conventional type , we are waiting .
Thanking you
Lazarus
Anonymous Poster (1); biswanath.das (1); chaterpilar (1); dlazarus (1); ramvinod (1)
