Previous in Forum: how does it work   Next in Forum: Fuses AC and DC
Relay Tester
02/21/2008 1:22 AM
Can someone come up with a simple tester to test relay contacts. Example, those 24vdc interfacing or control relay. I have two methods. one is to draw current through the contacts using light bulds or resistor. Second method is to measure the contact resistance when the relay is energized.
Re: Relay Tester
02/21/2008 4:53 AM
Sounds like you are doing fine.
If they are plug in realys, build yourself a test box with a socket on it, a suitable load, LED indicator and push to test switch. Powered from mains or batteries.
Re: Relay Tester
02/22/2008 3:56 AM
The general concept of such a tester depends on some questions which determ the requirements:
1. Is it a go/nogo test for incoming goods ?
2. Is it a fails per cycles test ?
3. Single pieces or higher volume?
4. Do you need protocoling ?
Even at higher volumes it is possible to build a simple tester with automatic measurement and protocol function as there are many cheap hardware solutions talking with EXCEL, par example, via RS232 or HPIB.
Your both methods are ok as they concider the two main failure conditions of relais:
(nearly) no load, which means very low voltage or current switched, and
(nearly) full load with maximum voltage/current switched.
For both measurements you should define a go/nogo border with some tolerance, the first one is the resistance, the second one the voltage drop under load conditions.
Hope that helps,
Regards Uwe
The sum of intelligence on earth is a constant. And the population grows and grows and .....
Re: Relay Tester
02/26/2008 6:12 AM
Any pocket continuity tester can do the job. These days, a basic multimeter can be had off-the-shelf from major home improvement outlet for less than £10GBP, including local taxes. It might prove a worthwhile investment?
Register to Reply 3 comments
PWSlack (1); user-deleted-1105 (1); uweka (1)
