Previous in Forum: Material Mixer Equipment   Next in Forum: Air Velocity
Pro/E Mechanica Analysis
02/21/2008 6:28 AM
I have just started to use Pro/E-Mechanica struture in the indepedent mode. I have been able to perform single part analysis but not assembly analysis. Suppose if i have Assembly and i need give weld connection between the parts (inside the assembly) and run the analysis.after that i want to see the stress and deflection on any particular part (like ansys-work bench).is it possible in pro/E mechanica?If so, can you tell? it will be greatful,if you share any tutorial related to that.
User-tagged by 1 user
Re: Pro/E Mechanica Analysis
02/22/2008 9:01 PM
You can run the analysis in the assembly environment. Do you design the
products' structure ? what kind of product do you design?
08/22/2008 4:33 AM
shd@dharmap.com
