Previous in Forum: Permissible Rolling Ratios   Next in Forum: Where Can I Purchase Some Parts?
PU Topcoat for Helmet is Soft
05/19/2006 8:25 AM
Nguyen Minh Son writes:
We use product Auto Clear Plus HS (a kind of PU varnish) of Akzonobel for coating on the shell of helmet (shell made from fiber glass). We mixed varnish and hardener in accordance with ratio that the manufacturer recommended. After spraying the varnish and flash-off 30 minutes, we put the shell in the oven at 60 degree C in 6 hours. Then we assembled components of the helmet and packed it inside a fabric bag. The inside of fabric bag is velvet which is made from polyester. After packing for 8-10hrs, on the surface of varnish appears some traces of fabrics of the packing bag. Temperature of our factory is about 32-34 degree C.
Does anyone know why this would happen? And is there a solution for this problem? Thank you very much.
Good Answers: 918
Contact the paint manufacture
05/19/2006 9:09 AM
They can tell you best practices and see if you are doing something wrong.
depends on what you mean by dry...
05/20/2006 3:36 AM
I'm no expert but in my experience with paints and epoxies and such there's dry/cured and then there is really dry/cured. Perhaps you need to let them set out for 8-10 hours or longer before packing them. Possibly the coatings is "cured" but not really HARD?
Good Answers: 918
Re:depends on what you mean by dry...
05/20/2006 7:58 AM
You probably are right. Check the paint manufacture's process recommendations. I would bet there is a cure stage that you must go through and a post-cure stage.
I know with some heat settable epoxies you cure at one temperature for a period of time and then a post-cure is done at another temperature that is slightly higher.
soft top coat
07/31/2006 11:15 PM
Check you product storage and the age of the coatings. Some coatings will not dry if they have ever frozen in storage or in transit.
Anonymous Hero (2); dadw5boys (1); rcapper (1)
