Previous in Forum: Mayday!   Next in Forum: Yesterdays' Industrial Revolution Todays' Energy Revolution
8 comments
Machinable Liquid Metal?
02/25/2008 11:10 AM
20 odd years ago, while serving my apprenticeship, the company i worked for used a liquifiable metal ( i think it was aluminum ) which we used for pouring into machined cavities to enable the machining of the outer shell of a given part (also aluminum - 6061 ), then after machining the outer profile, we would boil it in water, i believe, to re-liquify it and simply pour it back out, to be used over & over again. For years i remembered the name of this material, but i have since forgotten it. I need to be able to locate a supplier of this product. Once it was poured into the cavity, after a given amount of time, it cured and became machinable itself. Anyone know what i'm talking about? Thanks in advance
Re: LIQUID METAL
02/25/2008 11:33 AM
Cerro Metal Products offers several low-melt-point alloys, from 117°F on up.
http://www.cerrometal.com/lowmelt.html
Good Answers: 266
Re: Machinable Liquid Metal?
02/25/2008 3:44 PM
02/25/2008 6:11 PM
right you are ozzb!! thanks alot...you are the guru!!
02/26/2008 7:02 AM
Search, "low fusing alloys".
Bobguz
"If we all worked on the assumption that what is accepted as true is really true, there would be little hope of advance." -- Orville Wright
02/26/2008 7:21 AM
It is unlikely to have been aluminium, as the melting point of the pure metal is too high for it to be liquefied in contact with hot water at ambient pressures.
http://en.wikipedia.org/wiki/List_of_elements_by_melting_point
There are several low-melt alloys that have varying quantities of bismuth in the composition; some are commercially available as solders.
http://www.gwneale.co.uk/lowmelt.html (other suppliers are available).
02/26/2008 9:18 AM
Hope these low melt alloys do not contain Lead?
02/26/2008 9:45 AM
Tin......Baaaaabit...be careful some of the earlier low melts contained lead. Which is OK, as long as you keep your fingers out of your mouth.
"I had not anticipated that the work would present any great difficulites" SHACKLETON
Good Answers: 243
02/26/2008 11:08 AM
BAck in the day when kids were encouraged to learn by doing, Wood's metal was the material you described.
Now that everything has terrifying public health impact, Wood's metal is no longer cast into spoons by wise a$$ fraternity boys.
Fields metal is the lead free alternative.
here's a link:http://en.wikipedia.org/wiki/Field%27s_metal
Gunsmithiong catalogs also carry the cerro alloys, for use in making chamer or bore casts.
milo
Register to Reply 8 comments
bobguz (1); camstar (1); Milo (1); NiCrMoNoMore (1); ozzb (1); pantaz (1); PWSlack (1); yesyen (1)
