Previous in Forum: Rut-Ro! It's Global Cooling Again!   Next in Forum: UK supplier of M15 fasteners wanted
9 comments
pelletized product storage tank content calculation
02/27/2008 9:48 AM
Its a software and a manufacturing issue so .... I ended up putting it here.
We have several types of pelletized product storage tanks each consisting of a conical roof section, cylindrical main section and a (truncated in some cases) bottom section. On the roof(s) of the tank(s) there are gauge pipes, from the measured product level the tank contents (volume) is calculated.
The calculation is done with an OLD Excel worksheet that is protected and not very accurate (working in 25 cm incremental level steps!). Nobody knows HOW it works exactly and we can't change it...
So I've been working on a new calculation method (designing it in Excel, to have a working basis for the program I'm going to use said method in) and was wondering if anyone here would be so kind as to check my method? Alternatively I'd LOVE any methods others have developed for the purpose.
Pathfinder Tags: bulk storage tank volume
Good Answers: 15
Re: pelletized product storage tank content calculation
02/27/2008 10:02 AM
You could try load cells. There have been some previous threads in this forum.
downhill slide to 112 (damn memor.)
Good Answers: 266
02/27/2008 10:47 AM
Not knowing the nature of the business and how critical the volume measure is on a time bases. There laser measuring devices that could accurately take a measure and transfer that measure to a program to give real time volume of your storage containers.
02/27/2008 11:02 AM
OK. From first principles, and assuming the base of the silo is flat and circular for the moment and that the fill point is in the centre:
  • Let the diameter of the silo be D
  • Let the natural angle of repose of the material be Θ
  • Let the height of the cone be H2
  • If 2H2/D < cos(Θ) then the cone is not touching the sides of the silo. From the actual H2 calculate D', being the actual diameter of the base of the cone. If D/2H2 ≈ cos(Θ) then the cone is touching the sides of the silo and is standing upon a cylinder of material which is itself standing upon the flat base of the silo.
  • Using either D or D' calculate the volume of material in the cone V2 (1/3 base area times H2).
  • If the cone is standing on a cylinder, let the height be H1. Calculate the volume in the cylinder V1 using diameter D (base area times H1). [If H1 is zero then V1 is zero.]
  • Add V1 and V2 together to obtain total volume of material V.
Does that look a bit like what is going on in the worksheet?
Is there any allowance in the worksheet for slump as the material flows out?
And what is the new calculation method proposed?
02/27/2008 1:29 PM
The way my method works (dang, why can't I attach an Excel sheet here?) is taking the physical tank data;
  1. diameter
  2. cylinder height
  3. roof height
  4. bottom height
  5. bottom bottom diameter (can be zero)
For each gauge location the following values are used / calculated;
  1. distance from edge
  2. length of gauge pipe
  3. in-roof space
  4. in-bottom space
  5. maximum gauge length (cylinder height + 2. + 3. + 4.)
For the NORMAL calculation I take a "top" and an "edge" gauge measurement and (from the height distance relative to the cylinder top and the horizontal distance between them) calculate the product cone angle. By extending the cone I get the product height at the tank edge and the product cone height. The tank contents, then, are the product cone volume + the cylinder under the product level + the bottom volume. Amusingly this even works for a negative product angle; the product cone becomes a negative value then.
Things get tricky with non normal conditions;
  • product level under the cylinder level (using the bottom angle - product angle intersection)
  • product level > cylinder height (using product angle - roof angle intersection)
I've got the distinct impression that I'm missing something however?
02/28/2008 3:11 AM
Hi, if you still want to know the formula in your file than hack it. I mean there must be many tiny softwares that can help you by pass the protection of an Excel file. Try some Googling.
02/28/2008 6:58 AM
For storage tanks, we have to calibrate them from time to time (may be 5 years intervals), since its shape (roundness) changed by time due to buckling. It must to adapt the measured capacity with the actual capacity.
There are a contractors who measure and collect a lot of data about the ovality occurred to the cylindrical portion of tank and make the required formula.
04/28/2008 4:44 AM
OPERATION & MAINTENANCE
Finding volume in partially filled tanks
Using an HP-97 desk calculator, you
can easily determine the volume
of liquid in a horizontal tank
if you know the tank dimensions
and the height of the liquid.
Ing. Enniàio Santi, Monda S.p.A., Italy
ð Horizontal cylindrical tanks are common in the chemical process industries. The level of the liquid contained in these tanks is usually indicated by a gage glass, but finding the liquid's volume calls for some tedious calculations, particularly if the tanks have
dished heads. - -
A method of calculating such volumes was given in an article in the June 11, 1973 issue of Chemical Engineering, on p. 130. This technique has been pro­grammed for the HP-97 desk calculator to give quick, accurate answers. As a bonus, the program also calcu­lates volumes of partially filled spherical tanks and of vertical tanks.
The formulas used are:
As = (Rc)2 cos-1 [(Rc-h)/Rc]-( Rc- h)(2 Rch- h2)1/2 (1)
Vdh =(2p/3)[( Rc)3 -B3]+p[RcA2 -BC2] +
A{(Rc)2[sin-1(B/Rc)-(p/2)] + BD} —
2/3{(p/2)[3(Rd)2 -(Rc)2]Rc-
[2(Rd)2 + C2 ]B sin-1(A/C) .+
(A/2)[4(Rd)2 -(Rc)2] sin-1 (D/Rc)-
2(Rd)3 sin-1 (RdD/RCC)-½ABD}. (2)
Note that in the 1973 article, the last two terms of Eq. (2) were incorrectly shown as being positive rather than negative. For Eq. (1) and (2), Vdh = volume of the two dished heads; h = liquid level; Rd = radius of the cyl­inder; Rd = radius of the dished heads; A = [(Rd)2 -(Rc)2]1/2 ; B = Rc - h; C = [(Rd)2 - (Rc - h)2]1/2
D = [(Rc)2 - (Rc – h)2]1/2.
Vh = (ph2/3)(3Rd)2-h) (3)
where: Vh = volume of a spherical segment to level h;
Rd= radius of the: sphere; h=Rd[(Rd)2-(Rc)2]1/2 =Rd–A.
The combination of the three formulas provides the volume of: a horizontal tank with dished heads- Fig. 1a; a horizontal tank with hemispherical heads- Fig. 1b; a horizontal tank with flat heads-Fig. 1c; a spherical tank- Fig. 1d; and a vertical tank- Fig. 1e.
(text continues on p. 147)
The program first calculates the volume of the two heads and adds the volume of the cylinder—both at level h. For the two heads, if the tank is more than half full, the value of the headspace is calculated and then subtracted from the whole volume of the two heads.
In all cases, if the dimensions are entered in meters, the volume in liters will be obtained by pressing Key A.
If the dimensions are entered in feet, pressing Key B will provide the volume in gallons. (N.B. Before enter­ing program, initialize calculator to radians.)
Horizontal tank with dished heads (Fig. 1a).
Key in:
Example
Liquid level h Enter ­ l.00T
Cylinder radius Rc Enter ­ 2.00Z
Dished-heads radius Rd Enter ­ 6.00Y
Cylinder length L 3.00X
Press key A—~ volume 7,924.97L
Horizontal tank with hemispherical heads (Fig. 1b).
This is a special case in which Rd =Rc
Key in:
Cylinder radius Rc Enter ­ 0.50Z
Dished-heads radius Rd Enter ­ 0.50Y
Cylinder length L 2.00X
Press key A—~ volume 2,094.40L
Horizontal tank with flat heads (Fig. 1c).
The same as Fig. 2, but here Rd =0.
Key in:
Spherical tank (Fig. 1d).
The same as before except that the cylindrical part has zero length (L) and the radius Rc is equal to Rd.
Key in:
Liquid level h Enter ­ 2.00T
Cylinder radius Rc Enter ­ 1.00Z
Dished-heads radius Rd Enter ­ 1.00Y
Cylinder length L 0.00X
Press key A—~ volume 4,188.79L
Vertical cylindrical tank (Fig. 1e).
In this case the height of the liquid becomes L; hi is 2Rc and Rd is zero.
Key in:
Diameter of the tank h=2 Rc Enter ­
Radius of the cylinder Rc Enter ­
Radius of the dished heads Rd = 0 Enter ­
Liquid level Press key L
Press key A ® volume
Roy V. Hughson, Editor
The author
Ermimio Santi work for Monda S.p.A., 37058 Sanguinetto (VR),VialeRoma 9, Italy, as production manager in a food plant. His experience has been in food engineering and food processing. He holds a degree in chemical engineering from the University of Padua, is a licensed professional engineer and is registered in the Italian Ordine Professionale degli Ingegneri.
I've used these equations to calculate the incremental (decimal fraction of an inch) volume of several vertical and horizontal storages in an Excel Work Book.
lwegrzyn2000@yhaoo.com
CHEMICAL ENGINEERING JUNE 18, 1979 147
II
11/06/2008 2:21 PM
dished heads. - -
Key in:
Example
Key in:
Key in:
Key in:
Key in:
The author
This is what I used in an Excel spreadsheet to calculate the partial volumes of various vertical and horizontal (dished head) storage tanks. This system of equations was in service for over twenty (20) years until the plant closed
Larry A. Wegrzyn
11/17/2008 7:24 AM
Thank you for your feedback (Ad C. Lockhorst here) BUT apparently most respondents quite failed to realize that my question is about a tank used for SOLIDS (well, pelletized material) rather than liquids. For liquids it would be rather easier to produce a calculation method because only ONE gauge would be needed and the calculation would only switch if the measured level was below or above the cylindrical part of the tank.
With solids, however, at least TWO gauges are needed as the product will have an angle (positive or negative): the product level therefore has to be calculated. Even worse is the fact that this calculated level is only valid if it is within the cylindrical section of the tank (otherwise the top / bottom wall intersection with the product angle line has to be found).
I THINK that the method I finally worked out (one base method, five special case methods) is acceptable. If anyone would be kind enough to review it for me (5 pages of text (DOC file) plus a simple calculator program) ..... let me know via alockhorst@chello.nl please. If my method is okay I'll put it up here (after its checked).
Register to Reply 9 comments
Abdel Halim Galala (1); Anonymous Poster (4); ddk (1); Ghoti (1); ozzb (1); PWSlack (1)
