Previous in Forum: It's a Visual Thing for Me!   Next in Forum: What is a 10 Penny Nail?
25 comments
Sun Lightning
02/28/2008 10:38 AM
Sun Lightning
It will be possible to concentrate sunlight (say- concentrating mirrors), pump it trough flexible optical cable and finally deliver it to a mirrored glass (?) for (1 way) lightning purposes at let say, level – 2 in the building?
Pathfinder Tags: sunlightning
Re: Sun Lightning
02/28/2008 10:42 AM
Is there someone on the second floor that you don't like?
I assume you mean lighting, not lightning.
This can be done. There is a company called solatube that does this more or less. You might try looking at their website.
Re: Sun Lightning
02/29/2008 11:30 AM
I have a couple of SolaTubes, and they work well, but they do not concentrated the light, and they do not use flexible light guides. They simply reflect incoming sunlight through polished aluminum tubes to the destination area. A diffuser spreads the light out somewhat, but it is hardly large area lighting.
Re: Sun Lightning
02/29/2008 2:08 PM
My parents have one of the larger Solatube (about 12inches across) and it lights up their whole living room.
Re: Sun Lightning
02/29/2008 4:01 PM
I do have the smaller 10" ones. the one in my entry lights up the whole (≈4'x8') entry and allows my wife to grow plants there. The other is to light up a dark corner of the living room, again for the benefit of plants.
Good Answers: 143
Re: Sun Lightning
02/28/2008 10:43 AM
Wasn't there a village in Switzerland that tried using mirrors to bounce in sunlight from behind a mountain?
Re: Sun Lightning
02/28/2008 10:46 AM
yes, there was a village....
Good Answers: 143
Re: Sun Lightning
02/28/2008 10:55 AM
No, a FLAT mirror, not the focusin...ssss
Re: Sun Lightning
02/28/2008 11:52 AM
http://www.loftshop.co.uk/products.asp?catID=2
Yep. Done it on a recent home extension project. It works a treat.
Re: Sun Lightning
02/28/2008 11:57 AM
Is that just a skylight or does it have the mirrored conduit that carries the light down to the room?
Re: Sun Lightning
02/28/2008 12:28 PM
Thanks for the Solatube site reference. Interesting concept, the OptiView light diffuser.
To conceptualise:
Question 2: Could a high transparency sheet of glass (for example – 1000 mm x 1000 x 5) be pumped with light from an optical (glass) fibre cable (50m long – for example)?
It is supposed the sheet of glass to act as light diffuser. One side mirrored / coated with high reflection material, to reflect light in only one direction (ceiling / wall lighting).
Question3: What about the contact between the fibre cable and the light diffuser (sheet of glass)? Technical feasible?
Re: Sun Lightning
02/28/2008 1:53 PM
I think it's feasible. 50 feet should not be a issue for the right fiber optic cable. I would suggest many fibers, rather than just one big one, connected all along one edge of your glass. The connection would require something to match the index of refraction between the fiber and the glass. Plexiglass or some other plastic might be a better match than pure glass. I don't know about the availability of fiber optic cables for this application, since they are typically made to carry light at frequencies outside the visible spectrum, but I'd guess they are out there, since you can buy fiber optic lamps and probes.
Getting light into the cable would be another issue, since the sun is always moving.
It seems complicated.
How about just collecting the sunlight in photovoltaic cells, and recreating it with LEDs? I doubt anyone could tell the difference.
Re: Sun Lightning
02/28/2008 2:23 PM
About "the sun is always moving" see please, HELIOTS® and DoubleSun®
sun multiplicator we doubled the sun at youtube. Ok for the photovoltaic cells approach.
Could it be done, for just the sunlight?
Re: Sun Lightning
02/29/2008 4:22 AM
The inside surface of the conduit is highly-reflective thin metal (not sure which one) sheet, and cylindrical. It ducts natural light from above a sloping roof surface into a bathroom that would otherwise have none, the room not having any outside walls into which a window might otherwise be inserted. The bottom of the duct has a clear polycarbonate diffuser, which has a pattern similar to that found on some commercial fluorescent light fittings though it is circular and domed slightly, that is attached to the underside of the bathroom ceiling and spreads the light out in a large diffuse cone into the room below.
(From an entirely-satisfied Customer.)
Good Answers: 266
Re: Sun Lightning
02/28/2008 12:36 PM
Windows work to bring a little of the outside inside fresh air and sunlight.
Re: Sun Lightning
02/28/2008 12:47 PM
Unfortunately, not everybody has the opportunity to work by the window...
Good Answers: 143
Re: Sun Lightning
02/28/2008 1:05 PM
I used to work in a subbasement, so i bought a cheap picture of a window and hung it on the wall.
Good Answers: 37
Re: Sun Lightning
03/03/2008 8:27 PM
You need to move upscale a little: read "Light of Other Days" at http://www.scifi.com/scifiction/classics/classics_archive/shaw/shaw1.html to see how to do it right!
" Ignorance and arrogance have more in common than their last four letters. "
Re: Sun Lightning
02/29/2008 6:51 AM
You made my day. Thanks very much for this INFO.
It's amazing how things happen.
A far incredible idea was exposed and already
somebody succeeded to have a product on the market.
Long life to creativity and mankind.
We will survive the "global warming treat".
PARANS - the name to remember!!
http://parans.production.llr.se/
Thanks to the flexibility and high light transmission of the fiber optical cables, the Parans System can transport the sunlight to most locations in a building without occupying valuable space.
Re: Sun Lightning
02/29/2008 9:01 AM
Sun lightning? Solar activity? Hmmm...
But assuming you mean lighting, There is an interesting debate going on for years among the world leading archaeologists as to how did the pyramids artists/builders painted their wall paintings on the internal walls in TOTAL darkness? you say light torches, Well, there are NO carbon deposits on the walls or ceiling, something that would have definitely been left by by a burning torch. The general agreement is that they had some very sophisticated way of delivering sunlight sometimes further than 2500' (800m) by means of mirrors, optical tubes or? Remember, there are no evidences of any kind of the existence of glass mirrors at the time!
You see apms55, nothing new...
Wangito
Never trade luck for skill.
Re: Sun Lightning
02/29/2008 9:21 AM
Maybe they painted their painting on the internal walls before the roof was built.
Re: Sun Lightning
02/29/2008 9:59 AM
d'oh!
Re: Sun Lightning
02/29/2008 11:45 AM
concentrate sunlight = Remove all water and sun juices until you reach 99% concentrate. Carry up to second floor, release and just add water! Instant sunlight!
Sorry, it's Friday!
Re: Sun Lightning
03/04/2008 12:49 PM
Hi apms55.
I contacted once sunlight-direct to ask for a quote. It was around $20,000 for a whole system, including installation.
Another smaller system is Himawary (sun-flower in Japanese):
http://www.himawari-net.co.jp/e_page-index01.html
The problem is they never answered my emails. Their price is around $10,000.
Both have all necessary components: solar tracker, solar collector, optical fiber and light fixtures. There are two main differences in their technology:
a) sunlight-direct use plastic while himawary use silica optical fibers
b) the IR and UV are filtered at sunlight-direct while himawary exploits spacial focusing for not puting them into the main optical bundle.
I hope this helps.
Regards,
Michael
Re: Sun Lightning
03/04/2008 2:11 PM
Hi Michael
It was of great help. Including my "hidden agenda" was also disclosed: BIO GROWTH LIGHTING.
Allow me to repeat my comment about the same idea being "discovered" and developed (almost) simultaneously in at least 3 (so far) different places.
Long life to creativity and mankind. We will survive the "global warming threat".
Summing up we have:
http://www.himawari-net.co.jp/e_page-index01.html.
Any more contributions?
Best regards
apms55
Good Answers: 97
Re: Sun Lightning
03/04/2008 8:56 PM
Hello apms55,
What threat? Warming? How so?
If we are to believe the data showing a thinning of the ozone layer which blocks damaging radiation from space entering the lower altitudes and also from the earths surface out into space. But also recognize that frequent nuclear explosions have sent particulates high into the atmosphere blocking radiation inhibiting global warming; as I'm writing I'm losing context of you're statement.
Yeper ya lost me there dude er? yep...
Register to Reply 25 comments
apms55 (5); bhankiii (6); bwire (1); DGCYS (1); dkwarner (2); Hottech (1); Jonny5 (1); ozzb (1); PWSlack (2); Ron (1); TVP45 (3); wangito (1)
