Previous in Forum: Where can i purchase a sawdust pellet machine?   Next in Forum: Amount of Wattage Needed to obtain 600 Degrees
Calculating the Volume M3 from Q/h 32 point data set
03/01/2008 3:50 PM
How can I calculating the volume from a Q/H curve given the Flow (l/s)to head (mm)32 point dataset.
I have 2 different Q/h curves for the same installation measured by an Ultrasonic system through a rectangular flume.
One set has been installed for 3 years and the other has been produced after an indepth survey of the installation.
I need to compare the flows and calculate the volumetric difference between the 2 datasets as a percentage.
Re: Calculating the Volume M3 from Q/h 32 point data set
03/02/2008 3:48 PM
Check this manual page 25 or so.
http://www.hitechtech.com/EchoTrekManual.PDF
They show several weir configurations and the math to calculate flow rates. That should help you.
If I hear hoofbeats, why don't I ever think a Zebra might be around?
03/03/2008 4:20 AM
Various ultrasonic level meters have on-board algorithms to convert head to flowrate in open-channel configurations for various shapes and heights of weir. It is simply a case of entering the correct parameters intot he instrument, and the output will then be linear to flowrate. Do you have a copy of the user manual for the equipment in question? If so, then what does it say?
Good moaning!
Register to Reply 2 comments
