I am designing a piece of test equipment and am looking for a small air
pump to move a sample of gas around a closed loop of tubing. The flow
rate will be 1.0 scfh and the required pressure drop 0.5 inches of Hg
or less. The pump must fit inside a metal tube or have a very small
internal volume, and must be made of materials which will not adsorb or
desorb water vapor (preferably made of metal or glass). No plastic
components. Most important that the contents of the circulating gas
sample be completely isolated from the external air - so the pumped gas
must be hermetically sealed from the environment. A microminiature
magnetically coupled turbine would do the job, if I could find one.
