Previous in Forum: help on pic micro   Next in Forum: Caribbean Motor Conversion: 220V Three-Phase to 220V Single-Phase
why a transformer feeder is not provided with line isolator
03/03/2008 12:26 PM
why a transformer feeder say of 66 kV is not provided with line isolator towards the 66kV bus which it will feed.If the 66kV switchgear is fed by a cable feeder then it will have a line isolator.Will some explain why no isolation is required towards line side for a transformer feeder?
Good Answers: 19
Re: why a transformer feeder is not provided with line isolator
03/04/2008 2:06 AM
Query is not crystal clear to understand?
May be you can explain with sketch/ SLD
Ramesh,Freelance Electrical/automation Consultant
03/04/2008 10:28 PM
The purpose of an isolator is to enable the equipment or line to be taken out of service for maintenance in a safe manner. Perhaps in your system this can be done without the isolator in that particular location, hence the design engineer left it out.
It is good practice to have isolators in an outdoor HV switchyard because they provide a 'visible break' in the circuit and thus make it easy to visually ascertain that the equipment (circuit breaker, line, etc) is safe to work on.
You have to give more information (single line diagram?) before we can say anything more specific.
You might be interested in: Line-shaft Spools, Power Line Network Components
