Could someone explain to me what creates the "strobish effect" when you wave your hand at a CRT computer screen? It doesn't happen for LCD monitors or regular televisions.
60 hz. cycle flicker! The CRT screen go's on and off everytime the AC sine wave passes zero or 120 times a second. Hence the strobe effect. LCD's aren't affected by 60 cycle flicker.
This effect is most noticeable with an oscilloscope screen, which is a one line TV screen basically....
If you are chewing on a biscuit or something crunchy the vibrations in your head cause the eyes to deviate from the position the brain is pointing them at, and so the line on a 'scope screen will seem to have an odd waveform on it!!!
Which of course nobody else can see... I think this must be a similar effect to your waving your hand in front of the screen. As the screen is updated only every so often the strobing you get by moving you fingers in front of the picture depends on the speed of response of the phosphers of the CRT or the switching time of the LCD pixels...
Check your monitor settings I bet you're using a slow refresh rate on your monitor!!
John.
If you want to see something neat, get a thin string of elastic, hold it up in front of your TV, and pluck the string. As you pull on the ends of the elastic the frequency of vibration will change. When it's near the scanning rate of the TV picture tube, you will see the wave on the elastic string stand still!
