Previous in Forum: Expansion in Multistage Steam Turbines   Next in Forum: Problem of Snow Shoveling in U.S.
Calibrating Torque Wrenches and Tensiometers
03/05/2008 4:22 AM
I NEED A CALIBRATION PROCEDURE STEP-BY-STEP HOW TO CALIBRATE A TORQUE WRENCH.
I NEED A CALIBRATION PROCEDURE STEP-BY-STEP HOW TO CALIBRATE A TENSIOMETER.
Good Answers: 230
Re: CALIBRATION PROCEDURES
03/05/2008 4:27 AM
Hello yemenia
It is bad manners to use all CAPITALS in a Forum.
It is the same as shouting at the reader.
The word "please" would also be helpful, if you want assistance from others.
Kind Regards....
Re: Calibrating Torque Wrenches and Tensiometers
03/10/2008 4:06 PM
Hello Yemenia, try this site http://www.ncsli.org/resources/procedures/faq.cfm .Ordinarily calibration procedures are purchased however the National Council of Standards Laboratories publishes some free issue procedures available for downloading.
Google calibration procedures for more sites.
intellectuals solve problems, geniuses prevent them ~ Einstein
03/11/2008 8:44 AM
Thank you very much for your quick answer my inquiries.
Engineering Fields - Piping Design Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 27
05/08/2009 11:25 AM
Granted, I'm a bit late to this party; everybody has likely gone home already. However, future visitors to this thread may find the following to be informative:
Ever wonder why after using your recently "calibrated" torque wrench, you broke a bolt, you extruded a gasket or, your joint leaks?
Here's a radical statement sure to raise some hackles: Calibration of torque tools is useless if the aim in doing so is to ensure proper bolt load (is there any other goal?).
Regardless of how close actual torque is to indicated torque, a calibrated wrench applying the same torque to two identical bolts may produce two completely different bolt loads. In fact, in the extreme, one of these bolts could be too loose while the other may have been overtightened! in either case, one may be faced with joint failure.
Here's a link which expands on this: http://www.heviitech.com/Hevii_TorqueDanger.html
Best regards, HeviiGuy
Register to Reply 4 comments
BoltIntegrity (1); Sparkstation (1); taejonkwando (1); yemenia (1)
