The problem is to explain why single walled carbon nano tube with Vanadium pentoxide actuators move both ways (left to right and visversa) under constant voltage, i.e. not changing the polarity
I have looked and thought about it but I have come to a brick wall! I understand that:
For low charge densities, calculations and experimental results for charge transfer complexes of graphite and conducting polymers show that the strain due to quantum mechanical effects (changes in orbital occupation and band structure) changes sign from an expansion for electron injection to a contraction for hole injection. However, expansion results from both quantum chemical effects and electrostatic double-layer charging for high-density charge injection of either sign.
This I understand when the polarity is being reversed, but what I dont understand is as the voltage is kept the same where do the electrons "go" if the material is able to move in the other direction without a voltage change (positive to negative and visa-versa)
Here are the conditions, weights etc,
. MWCNT/V2O5 in Solution Na2SO4
MWCNT/V2O5 = 7.5/10mg
Voltage = +/- 0.8 Volts
Current =0.001-<0.0009 Amps
Environment = Na2SO4 1molL-1 , Sodium dodecyl sulphate 0.0082 M l-1
Electrodes = Copper, MWCNT/V2O6
Any help would be greatly appreceated! Please contact me if I have left anything out that might help in understanding my problem!
thanks to all!
Raphman
