Previous in Forum: Detail mathematical solution for selecting cable for a 500kva transfomer   Next in Forum: A Good Earthing Should?
How to read cable specs?
03/10/2008 10:25 AM
How do I calculate the cross sectional area of copper wires in a cable. For eg, the cable specs as follows,
AWG 22 (17/0.16SBCU) x 2C
I understand what AWG 22 means. What about (17/0.16SBCU)? Does the 17/0.16 refers to 17 copper wire with diameter 0.16mm? And what does the C in 2C means? Sometimes I see 2F too. I thought that the '2' means the number of parallel wires, am I right? I been searching for the internet for answers but in vain.
Please help. Thanks.
Re: How to read cable specs?
03/10/2008 11:22 AM
the 17 means the nos number of the cable, and the 0.16 is the square of each nos of the internal copper wire, SBCU is the kind of copper wire. X2 means the core quantity of the cable.
03/10/2008 11:38 AM
I'm a little confused over here.
17 means the numbers of the copper wire right? So 0.16 is the square of the internal copper wire. So it means the cross sectional area is 0.16 x pie x 17 cables right? For AWG 22, the cross sectional area is 0.326mm square. So which one is correct?
03/10/2008 12:59 PM
There is a difference between "linear millimetres, squared", and "square millimetres".
1) 17 x 0.16mm2 = 2.72mm2. Which will carry somewhere north of 25A-ish without getting too excited.
2) (0.326mm)2 = 0.11mm2. Which is a good size for a 0.5A fuse, maybe smaller.
2.72/0.11 = factor of around 25 between the two numbers. So, without having stated the context in the original post, which area is correct?
03/11/2008 12:39 PM
Yes, 17/0.16 refers to 17 copper wire with 0.16mm diamer and '2' means 2 number of parallel wires.
Thanking you.
Register to Reply 4 comments
Anonymous Poster (1); Dameos (1); PWSlack (1); Toma (1)
You might be interested in: Hookup Wires, Cable Ties, Cable Laying Services
