I am located in Delhi India.
I want to get guidance on constructing permanent outdoor single ground floor room about 50Sq meters floor area.
The outside walls should provide insulation from hot summer weather by reducing the inside temperatures to not more than30degrees celsius, when the out side temperatures are about45 degrees celsius.
The interiors should be fully illuminated with sunshine, by blocking the infra red rays and allowing the full visible light spectrum inputs.
If any artificial means are required for keeping the interiors cool, what will be the most energy saving alternatives?
What type of materials should be used for exterior walls. AAC blocks or any other alternative construction methods and materials can be considered.
What type of roof coverings and glazing should be considered?
