Previous in Forum: Do AC motors overcome DC series motors?   Next in Forum: Around the World in 65 Days
Canada - Member -  Member
Location: Hamburg NY (just south of buffalo) pre-Hamburg(1998) home was the Yukon territory of Canada
Good Answers: 27
Micro-valve for Steam
06/05/2006 9:13 AM
The braking assembly on my scale model steam engine has an actuator plate that moves between open and bypass. The plate has a .010 viton seal that slides over the base plate covering one of two .0520 steam ports. The problem is the o-ring keeps tearing or blowing out(I've polished/countersunk ports). Is there a miniature spool valve that can replace this? Or another type of solution?
Nothing is fool-proof to a talented fool
No o-rings
06/05/2006 10:42 PM
You might try a mod-logic valve from Dynamco. The spool is a precision fit to the body of the valve with no o-rings. It is all metal except for the end caps which are plastic. There is a 150 psi. limit though. At least on the one's I am familiar with. They may have other valves more suited to your application.
Always use protection.
06/06/2006 2:13 AM
If the plate holding the seal is strong and it can be pressed enought to adjust a metal, you could try a ring of the same size as the viton one but made with copper or soft aluminum alloy as those used in gas connections. If it works, saves a lot of efforts.
progress is the maturity to accept that it is better to have 1 today than loosing 2 tomorrow "Anonimous"
Register to Reply 3 comments
giuseppe (1); Keywalker (1); ZackPhilly (1)
