Previous in Forum: Memory ability   Next in Forum: hepa b cure
10 comments
How to Follow Something in Digestion Tube
03/11/2008 10:45 PM
What could I put in a small bag with feed and fellow the bag over the skin of the rumunant. Bag is in the digestion tube of a cow.
No magnets are allowed because some bags will agglomerade together. off course the cow is alive but little bit sqeezed.
Den
Re: how to follow something in digestion tube
03/11/2008 11:18 PM
How much is the cow worth (in survival or dollars), how much does a vet cost, and how much can you scrape together?
You need a vet who can tell you where the blockage is, just by the touch (experience). ASAP (As Soon As Possible).
03/11/2008 11:57 PM
The cow dosn't have a problem with that, The raison of the study is to calculte the time it takes for a portion of nutriment to move from a specific place to an other. we just want to follow it and mesure what potion is absorbed. i'm thinking of kind of sensor.
03/12/2008 11:29 AM
You could use an portable ultrasound machine and follow a swallowed 3/8" ball bearing. You could use a metal detector with a small search coil over the feces to see when the bearing was eliminated.
Re: How to Follow Something in Digestion Tube
03/12/2008 12:43 PM
if you could x-ray the cow periodically, you could follow a tungsten ball quite easily.
If not perhaps a small radio transmitter with external direction finders in three different axes?
Also have you thought about ultrasound?
Good luck JohnT
03/12/2008 11:52 PM
There are now small TV cameras which can be swallowed by a human to take photos all the way through the allimentary canal. The O/P is received by a digital recorder and displayed on a computer monitor.
Cameras are disposable and get flushed down the loo, but maybe cows are not as fussy about preloved cameras
Popular Science - Cosmology - New Member Popular Science - Biology - New Member
03/13/2008 5:25 AM
Are there swallowable cameras with microphones as well? If so, what is their audio bandwidth?
Thanks,
-- Rob
03/13/2008 6:50 PM
http://www.hoise.com/vmw/00/articles/vmw/LV-VM-08-00-25.html
I googled "swallowable Cameras" and got the above sire which describes the device.
It doesn't mention a microphone, dont think gastrpods are interested in the noise made by ulcers and the like, they just want to view them.
Do you want to feed such a device to someone and eavesdrop??
Don't vote it only encourages them
Good Answers: 11
03/13/2008 9:49 AM
The smart pill uses basic radio technology in a sealed "pill" that will be easy for a cow to swallow and pass. Should give you all the information you need.
If the cow has a magnetic slug in it's first stomach it may have to be removed so that the pill isn't captured by the slug.
http://www.smartpillcorp.com/
Eric
03/14/2008 12:11 PM
I thought the poster was most interested in knowing the time a food was spent in each stomach compartment. Reading about the smart pill, I don't see how that would be able to give you location tracking data, especially in a cow, which has a stomach unlike a human. With a swallowed metal marble, you would have to use a Xray(cat scanner) but very impractical, or ultrasound(most likely), or a metal detector with pin point capability(cheapest). An RFID tag would not work, since you could not pin point the exact location.
03/14/2008 5:30 PM
A company called Calypso make a system for accurately tracking movements of the prostate for radiotherapy. It consists of 3 tranplanted radio transponders and an array of transmit/receiving antennae. Works in real time to an accuracy of a mm in 3 axes.
Perhaps an adaptation of the ideas behind this technology would suit yoour requirements
Anonymous Poster (2); ca1ic0cat (1); Kilowatt0 (1); Lleros MaHarg (2); Lleros Marharg (1); ot1 (2); rsmyers (1)
